Stagescape : Loud Pink Noise Trough Inputs 9 To 16 Recording Wave Files
stagescape record pink noise
7 replies to this topic
#1 pierrebriend
pierrebriend
  • 67 posts
  • Registered Products:5
Posted 08 May 2013 - 11:37 PM
Today I checked the results of the record session , then I was disappointed : The recording of the output mix is OK but requires some balance and effects updates. Nominal. The wave files of inputs 1 to 8 are OK, BUT the record files for 9 to 15 are not audible, there is a loudy pink noise which is louder than the signal of the instrument !!! The same trouble is occuring on the different sessions I already recorded with different set ups. Can you help me to understand and fix the problem. The firmware version is 1.1. It is a trouble related to the mixer, not to the connections because the mix output recording is OK. Did anyone have this trouble. What could I try or test before contacting my purchaser?
Thank for your help
#2 ArneLine6
ArneLine6
    Line 6 Staff
  • Product Management
  • PipPipPip
  • 564 posts
  • Registered Products:1
Posted 09 May 2013 - 06:46 AM
Are you listening to the files on a computer? Which software do you use? Which instruments did you record to which track?
The fact that your recorded mix sounds ok means that most likely the files must be ok and what you are experiencing could be happening in your listening setup.
If you could describe the setup and the tracks maybe we can get to the bottom of this.
  • 1
#3 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 09 May 2013 - 08:48 AM
Can you post a small section of the affected wav files?
#4 pierrebriend
pierrebriend
  • 67 posts
Posted 10 May 2013 - 06:30 AM
I posted all the information in the support ticket 208712. I don't know how to attached files in the forum reply form....<br />My SD Card is a SDHC Sandisk 32Go card.
#5 pierrebriend
pierrebriend
  • 67 posts
Posted 10 May 2013 - 06:46 AM
The set up is roughly like this<br />input 1 to inpout 7 : singer mics<br />Input 8 Keyboard 1 (DI 48V)<br />Input 9 DI of Galien Kruger amp<br />Input 10 DI of AER amp<br />Input 11 SM57 on guitar amp<br />Input 12 SM57 on guitar amp<br />Input 13 Aux input (drums)<br />Input 14 N/A<br />Input 15 passive DI on Keyboard<br />Input 16 passive DI on Keyboard<br /><br />48V in fed on input 7 to 12<br /><br />The corrupted files are from 9 to 16
#6 line6jonb
line6jonb
  • 69 posts
  • Registered Products:3
Posted 10 May 2013 - 01:25 PM
I have reviewed your support ticket, and will respond to that ticket right now, but for the sake of the forum I wanted to reply to you on the forum.  Are you sure that you are using a class 10 SD card?
Can you possibly test another recording with a different class 10 SD card to see whether or not it is an issue with that specific SD card?
#7 pierrebriend
pierrebriend
  • 67 posts
Posted 10 May 2013 - 04:02 PM
I already have ordered a class 10 sd card. I'll keep you informed. Thank you for your help.
#8 davec69
davec69
  • 84 posts
Posted 06 June 2013 - 04:22 PM
Try creating a new setup from scratch, and recording again.  Worked for me.
Also tagged with one or more of these keywords: stagescape, record, pink noise
