Pod Hd500x Patch Questions...
5 replies to this topic
#1 bignath
bignath
  • 30 posts
  • LocationMt Gambier, South Australia
  • Registered Products:1
Posted 26 October 2013 - 10:42 PM
Hi everyone,
just a couple of quick questions regarding my new 500x...
1. Is there a way where you can either on the pod itself or using the edit software, to easily "delete" a patch? Or do you have to go to the patch you don't want anymore, and manually remove everything...
2. The edit software looks like a really useful timesaver when compiling patches, but is there a way where you can print out the data of each created patch?
For me, i'd like to be able to keep a folder of all my patches I create over time as a hard copy, so if needed, I can rebuild patches if I am away from my computer...
Cheers in advance,
bignath
GEAR STUFF:
PRS Custom 22 w/Birds - MIM 60's Players Strat - Fender Hot Rod Deluxe - POD HD500X - Ungodly amount of stomps....
"1 - Cut a hole in a box. 2 - Put your junk in the box. 3 - Make her open the box......and that's the way you do it" - D!#k In A Box (The Lonely Island)
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15448 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 27 October 2013 - 04:40 AM
1. There is no 'delete' function. You delete a patch by overwriting/replacing it with a different patch. The easiest way to do this is to use the editor and drag/drop an 'empty' patch to the location you want to delete. You can create an empty patch, or use the New Tone preset that comes with the User setlists in the factory presets.
2. No - there is no printout capability, nor is there an export capability (e.g. to an Excel spreadsheet). However, some users have created templates to manually enter preset data into a printable file.
  • -1
.... John Lennon
#3 kmoed
kmoed
  • 61 posts
Posted 27 October 2013 - 04:58 AM
Hi everyone,
Cheers in advance,
bignath
You can always do a print screen of each individual patch.
#4 MrMarcosMiranda
MrMarcosMiranda
  • 12 posts
  • Registered Products:3
Posted 05 April 2014 - 01:55 PM
If I drag and drop, this won't "delete" but instead, it just moved the original patch. How do I completely get rid of a patch for good?
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15448 posts
Posted 05 April 2014 - 01:59 PM
Hold the CTRL button (makes a copy) while you drag/drop. This replaces (not just moves) the original patch.
.... John Lennon
#6 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 07 April 2014 - 02:45 AM
For exporting a list with preset names, try this one:
http://line6.com/sup...dit/#entry34157
