Dt50 212 Direct Out Recording
dt50 212 recording out
Best Answer phil_m , 30 October 2013 - 07:30 AM
The direct out on the DT50 has cab and mic modeling applied by default, so using an IR cab may give you some weird sounding results. If you've installed the 2.0 firmware update, you can turn that off by sending the appropriate MIDI CC message to the DT50, though.
Go to the full post
2 replies to this topic
#1 robyone
robyone
  • 35 posts
  • Registered Products:5
Posted 30 October 2013 - 06:51 AM
I want to use the direct out of my dt50 212;
My intention is the follow;
guitar, amp input, direct out, mic soundcard input...master amp level about 50%-60% (i use a SPL reducer for lowering the out volume) and add effects in cubase ( IR cab, delay or reverbs etc)
any help or suggestions?
Thank you  :)
#2 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
  • Registered Products:2
Posted 30 October 2013 - 07:13 AM
Sounds like a solid plan
#3 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9212 posts
  • LocationMinneapolis, MN
Posted 30 October 2013 - 07:30 AM   Best Answer
