Jtv 59p Doesnt Power Up
13 replies to this topic
#1 nicjw
nicjw
  • 25 posts
  • LocationVeendam, The Netherlands
Posted 30 October 2013 - 12:16 PM
Hello
Ive just bought a new JTV59P.
All models work when powered with the VDI cable
But not when i try to power them with the battery.
Ive charged the battery en all 4 green lights power up.
Help! I cant use workbench ..
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9065 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 30 October 2013 - 12:18 PM
Do you have a 1/4" cable plugged into the guitar?
#3 nicjw
nicjw
  • 25 posts
Posted 30 October 2013 - 01:17 PM
Yes i do!
#4 ozbadman
ozbadman
    Power User
  • PipPipPipPip
  • 1900 posts
  • Registered Products:4
Posted 31 October 2013 - 01:09 AM
Have you tried plugging into an amp that way, or just through workbench?
I'd try just with the battery, a 1/4 in cable, full guitar volume, and an amp to be sure that it's a battery conenction problem. It could also be the mag/model selector switch which is notorious for having issues to do with the knob being too long and bottoming out on the guitar.
#5 nicjw
nicjw
  • 25 posts
Posted 31 October 2013 - 03:52 AM
Hello
I have the problem when using workbench and also when using an amp.
The models do work when i use the vdi cable with my hd500
#6 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
  • Registered Products:6
Posted 31 October 2013 - 05:55 AM
Sounds like a battery connection problem since the models work when powered by the VDI cable.  Sounds like a defect.  You might want to check that everything is plugged into the circuit board.  The battery lights are part of the battery holder and they indicate that your battery is charged but not that the battery voltage is getting to the main board.  There is a plug that connects the battery holder to the board.  Maybe it's not making good contact.  I think you can check this without voiding your warrantee.
#7 nicjw
nicjw
  • 25 posts
Posted 31 October 2013 - 06:11 AM
Thanks,
I'll try that when i get home.
It's behind one of the plates on the back of the guitar i guess?
Is it possible that there is a problem with the input jack?
Because i've read that you need to inset a jack to make shure that the battery powers up.
Is it possible that the jack doesnt make proper contact?
#8 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 31 October 2013 - 06:52 AM
Yes it's also possible that the switch on your input jack isn't closing when you plug into it.  That provides battery power to the board.  Yes the board is under one of the plates on back.  I have a 69 and I could not resist taking the covers off when I first got it.  On mine it's the large cover on back.  There is a set of wires from the battery box to the board.  Another set to the input jack.  If the rest of your guitar is the way you like it, I would take a shot at fixing your problem.  If not, send it back.
#9 nicjw
nicjw
  • 25 posts
Posted 31 October 2013 - 10:47 AM
Hello
It didnt fix the problem...
To bad
#10 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 31 October 2013 - 12:02 PM
Did you verify that battery voltage is getting to the switch in the 1/4 inch jack?
#11 nicjw
nicjw
  • 25 posts
Posted 31 October 2013 - 01:39 PM
How can i varify that?
#12 Charlie_Watt
Charlie_Watt
    Guru
  • PipPipPipPipPip
  • 2515 posts
Posted 31 October 2013 - 03:19 PM
If you are asking I am not sure you want to do this.  Use a DVM but you have to know where to ground it.  There is a switch in the 1/4 inch jack that powers the board when the plug is inserted.  I'm an EE so I would not hesitate to do this but if you are not real sure what you are doing you may want to return the guitar since it does have a problem.
#13 audiotechnician
audiotechnician
  • 7 posts
  • Registered Products:1
Posted 02 November 2013 - 04:51 PM
You may already know but it auto powers off if the volume is at zero when using the battery.
#14 arislaf
arislaf
    Power User
  • PipPipPipPip
  • 1819 posts
  • LocationGreece
  • Registered Products:12
Posted 06 November 2013 - 03:00 AM
Since you just bough it, sent it back and get a new.
Before line6 was called line6... they used to do r&d for other companies like alesis + others. and when those customers came to visit the offices of line6 (before it was called line6) and the receptionist needed to warn all the guys who were designing products for other companies (and for themselves... ) who were like 'in the back' the receptionist would announce over a tannoy 'tellephone call for 'fred smith' on line 6' the cunning part was that they only had 5 telephone lines, so it was the secret code for "hide your sh1t the feds are comin'" or "someone's coming, let's hide these PODs that we aren't going to release for another few years so they don't see them"
BEST CABS: www.studiocat.com
