hardins1 Posted October 31, 2013 Share Posted October 31, 2013 I want to connect my hd 500 to my new hd pro x. can I use the spdif out from the hd500 and connect it to the spdif in of the hd prox? and how will that work if it does? or what would be my best option for connecting the two together? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 31, 2013 Share Posted October 31, 2013 I'm not sure if the HD Prox can assign the s/pdif input to one of its channel inputs (Input 1 or Input 2). You can test this on your HD Prox preset Inputs options. If so then you should be able to connect the two devices as you describe and process the HD500 output as an HD Prox input for additional processing. If not, you should still be able to route the HD500 analog output(s) into the HD Prox Line Input(s). Set the HD500 Output Mode to Studio/Direct and set the Line/Amp switch to Line. I know you can select the Line Input(s) as Input 1 and/or Input 2 for further processing. Quote Link to comment Share on other sites More sharing options...
