Internal Midi Messages For Looper?
midi looper
6 replies to this topic
#1 andrewkennedy
andrewkennedy
  • 4 posts
  • Registered Products:1
Posted 31 October 2013 - 03:23 PM
I own a POD HD500 which I use for solo gigs.  I generally leave it in looper mode with an acoustic guitar so I can do solos.
However, I find the looper feature restrictive in that once I get a loop going I can't change sounds (for soloing) without exiting looper mode.  I also have to switch my sound back to my clean sound before going back to looper mode.  This constant switching between modes means that solos are less seamless, there's always a (musical) delay at the start and end of each solo.
Is there some way to program extra midi commands into the looper buttons so that when I press the "play" button, it automatically switches my sound to a different patch as well?
Currently I'm considering buying an external loop pedal which seems like a waste.
Andrew.
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 31 October 2013 - 03:34 PM
Unfortunately I think you are discovering why most people find the pod HD looper to be unsuitable for live play. It is primarily designed to practice soloing (post mode) and to audition tones and edits (pre mode). Personally I have not been able to master the tap dancing required for seamless live use.
.... John Lennon
#3 andrewkennedy
andrewkennedy
  • 4 posts
Posted 31 October 2013 - 04:50 PM
What if I used Midi Controller Pedal to control the POD?  The controller could simultaneously activate the "Play", "Loop Exit", "Patch Change" button presses in one go yes?
#4 tcastudios
tcastudios
  • 17 posts
  • Registered Products:2
Posted 24 November 2013 - 05:37 PM
You can send midi to the itself by connecting Midi In to Midi Out.
I use two different ways depending on situation.
One (simpler) way if you want to be in looper mode.
In the patch you want to loop, assign F4 to program change
to your "solo" patch.
In the "solo" patch assign F4 back to your "loop path".
The other way is to be in ABCD mode and assign the
F1 to F4 to Rec, Play, Stop etc.
I also use this "midi patch" to jump from the last patch (D) of a Bank
to the first patch (A) of the next bank by assigning the Tap to
program change.
#5 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 311 posts
  • Registered Products:5
Posted 26 November 2013 - 07:40 AM
program change.
Are you saying that you setup the midi messages from the F1-F8 foot switches to control internal functions of the HD500?  If so that's pretty cool, I didn't know that was possible.  Could you elaborate more on that setup?
Thanks
#6 tcastudios
tcastudios
  • 17 posts
Posted 26 November 2013 - 12:06 PM
I don't know what to add really… connect Midi Out to Midi In and use the midi send options?
Cheers
Lennart
#7 chuskey
chuskey
    Iknowathingortwo
  • PipPip
  • 311 posts
Posted 26 November 2013 - 07:01 PM
Thanks for the reply.  I somehow totally looked past the first sentence of the original post where you said to connect midi in to midi out :)  That's a cool trick!
Also tagged with one or more of these keywords: midi, looper
