Metal Guitar Harmony Part
3 replies to this topic
#1 heath49036
heath49036
  • 13 posts
  • LocationMichigan
Posted 01 November 2013 - 12:14 PM
Hello,
I'm trying to learn the solo from the song "Clean my wounds" by Corrosion of Conformity. Its a 2 part harmony and I'm trying to set it up on my HD500. Any suggestions?
Thanks,
Heath
#2 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1100 posts
  • Registered Products:3
Posted 01 November 2013 - 01:11 PM
probably thirds in the minor key of whatever note the song starts on
  • 1
#3 brian6string
brian6string
  • 81 posts
  • Registered Products:1
Posted 02 November 2013 - 05:30 AM
I only listened to the song once, but some thoughts. What if you used a dual amp approach. Amp A would be the same as Amp B, but on the B channel, add a digital delay 100% wet and a very short time, maybe 24ms or so. The effect of that would be to slightly delay the sound getting there, so that it sound more like two guitarists and not one. Then on either A or B, use the Smart Harmony filter effect set to the key of your song and as suggested above, either to thirds above (as ginpoinmetal suggested) or fifths above.
The smart harmony thingy is a DSP hog so if this doesn't work out, use the same idea, but put a single amp after the mixer and use the A & B just for effects.
I noticed in the video that he doesn't have the harmony thru the whole solo so you might assign the Smart Harmony to a footswitch so up you can turn it on only at specific points.
  • 1
#4 joemama78
joemama78
  • 24 posts
Posted 04 November 2013 - 09:56 AM
You can set the smart harmony up or down a 3rd, but it sounds like the two parts diverge from that single interval. You can try to set the smart harmony so that you can adjust the interval with the expression pedal.
