Banjo Sound Popping Noise Jtv59
jtv59 banjo popping
48 replies to this topic
#41 paulsky
paulsky
  • 8 posts
  • Registered Products:2
Posted 17 June 2014 - 09:05 AM
hallo
its a bug in programing the banjo
same thing on tricone reso and biscuite reso
other models work fine
picked on all strings on all frets slow, fast, light, hard without/with different plectrum and with "same touch"
sound character change after some picks, it sound lower and banjo sound less banjo
and after some picks it change back and so it goes, good, bad ......
write a support ticket to make line6 aware of problem
paulsky   :wacko:
#42 musical1212
musical1212
  • 56 posts
  • LocationBirmingham, Al
Posted 25 February 2015 - 10:15 AM
The popping sound is rather like
I play a Gibson Mastertone with the 5th string removed and tuned like a guitar. Broadway plays like Hello Dolly, Chicago, and music in the Dixieland style required aggressive banging on the banjo, creating all kinds of obnoxious subtleties when closely scrutinized. I alternated between my real banjo and the model last weekend at Mardi Gras Mobile, AL. I fooled the band members. "How are you doing that?" I think your recording sounds very much like a banjo, and when added in with other appropriate instruments, is very acceptable. I say be aggressive, hit the strings hard, tremelo profusely, go on to the next song, and thank Line 6 that you didn't have to lug several instruments to the gig. (Unless you also had to forego extra pay for doubling)
#43 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
  • Registered Products:3
Posted 25 February 2015 - 10:52 AM
The banjo has an ADSR to simulate the low sustain of a banjo. The ADSR has to detect when you play a new string to reset the volume back to being loud again. This could cause popping noise.
For a minute there, I lost myself.
#44 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1664 posts
  • LocationUK
  • Registered Products:7
Posted 26 February 2015 - 03:34 AM
Thanks for your input.  I am glad to hear that the banjo model does match up to a real banjo in a band setting.  So it is working as it should and there is no problem with my JTV and it's rendition of the banjo.  Good to know!   Thanks again!    :)
#45 edstar1960
edstar1960
    Power User
  • PipPipPipPip
  • 1664 posts
  • LocationUK
Posted 26 February 2015 - 03:35 AM
Thanks for the insight clay-man.
#46 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 26 February 2015 - 10:03 AM
I don't think I ever noticed popping noises too much, but if the ADSR (attack-decay-sustain-release envelope) initiates too slowly then it could be turning the volume back up too late and basically cutting off some of the attack, creating a pop sound.
I haven't messed with the banjo long enough when I messed with my 69 to tell right now. Waiting on my replacement.
#47 stevekc
stevekc
    Gear Head
  • PipPipPip
  • 780 posts
  • LocationSan Luis Obispo, CA USA (central coast)
  • Registered Products:14
Posted 26 February 2015 - 03:34 PM
True - and the ADSR block in the DSP is also employed on other Variax Models too
FWIW - Id pay $$ if they could also removed the ADSR from the Strat model  too, so the Strat can finally sing like the Tele model !
#48 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
Posted 27 February 2015 - 06:06 AM
The Strat model might just be lower volume so it has the illusion of having low sustain, at least I hope so.
Applying an ADSR to the strat would be kind of pointless if your variax is a 69.
  • 1
#49 stevekc
stevekc
    Gear Head
  • PipPipPip
  • 780 posts
Posted 27 February 2015 - 11:06 AM
Make this request to Line6 management  - My ears tell me the ADSR DOES already exist in All Variax Strat Models regardless of year 2004-2015 - even my Variax 500 has a built in "lack of sustain" for its Strat models - this is why I use workbench and swap the Bridge PU for the Tele Bridge PU Model ( which removes the ADSR ) and allows far more sustain,  compared to the Strat bridge PU model  that employs the ADSR
