Switch Tones In Hd500x
Leandro24
I had a POD X3 Live and I used this feature (from the manual):
"Set up one sound on Tone 1, and a different sound on Tone 2, and switch between them instantly, with seamless transitions including delay and reverb trails. We like to refer to this as “Alternating†tones."
How do you do the same in HD500X?
Thanks!
Could you set up two amp models panned hard left and right? One on path A  panned completely left, and one on path B panned completely right - and then set up the volume pedal to be a PAN control, up (minimum) being hard left, and then down (maximum) being hard right. Then you could move from one amp sound to the next just by stepping down on the volume pedal.   I haven't tried it but can't see why it would not work.     Hope that helps.
