Custom Tone Glitches
4 replies to this topic
#1 gchaddock1972
gchaddock1972
  • 43 posts
  • Registered Products:5
Posted 03 November 2013 - 04:40 PM
someone please down load this tone ( Another tone in the wall) and let me know how the amp parameters show up. It should be master 50% sag 100% hum 50% both bias 100%.
http://line6.com/cus...ne/tone/243940/
  • 1
#2 Dutchguitarist
Dutchguitarist
  • 74 posts
Posted 03 November 2013 - 10:27 PM
OK, I checked this for you on my POD HD PRO. Except for the master all settings show up as you mentioned. The master however is at 1 o'clock (about 65%)
#3 radatats
radatats
    Power User
  • PipPipPipPip
  • 2323 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 04 November 2013 - 03:59 AM
I converted it to .h5s for POD HD 500 Edit and while it loads fine, all these deep settings are at 50%.  Interesting...
#4 gchaddock1972
gchaddock1972
  • 43 posts
Posted 04 November 2013 - 05:31 AM
So change the settings to the original settings I determined. Did you notice a difference? I do and its huge. Sag at 0% makes the tone transfer instantly. At 100% there is a bit of...well....SAG. The tone seems to flex a bit. The Bias set to 100% makes the tubes sound more like 6L6's. At 0% more like EL34's. Bias X I can't place my finger on but it makes a dif as well. Cab Parameters are crucial as well. setting low to 0% will make the  cab so beefy. res at 100% is a bit louder. Thump makes it do just that. I always set the decay at 0%. But if wanting a supper strat tone I will change it to 100%. Almost has a flange sound to it.
#5 pratikb
pratikb
    Iknowathingortwo
  • PipPip
  • 216 posts
  • Registered Products:1
Posted 04 November 2013 - 09:51 PM
I opened the patch in HD Edit after change the extension to .h5e, and it showed all the Amp and Cab parameter at 12 o'clock. Pic attached
