Turntable Through Ux8, Possible?
ux8 turntable
Best Answer TheRealZap , 04 November 2013 - 09:16 AM
I assumed you were already aware of that, but RCA to 1/4" mono TS connectors are pretty common....
if you wanted certainty you can get this as well: http://www.amazon.co...cm_srch_tsr_rtr
(or a similar phono preamp)
you'd still need the above adapters, but that will get you in at line level.
Go to the full post
6 replies to this topic
#1 Swaartbaard
Swaartbaard
  • 15 posts
Posted 04 November 2013 - 06:47 AM
Hi all,
I'm looking at purchasing myself a Rega turntable as an early Christmas present.
I don't have an amp though and was wondering:
Could I connect the turntable into my Line6 UX8 phono in and then have it play through the Studio Monitors I have connected to the UX8 output? Essentially the UX8 would be the amplifier... And could I do this without the PC being on essentially bypassing the PC???
Flip I hope the answer is yes!
Thanks,
Dean
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 04 November 2013 - 06:56 AM
i think you can, phono level is pretty low though... i'd be worried about cranking the gain/trim possibly introducing noise...only way to know is to try though.
#3 Swaartbaard
Swaartbaard
  • 15 posts
Posted 04 November 2013 - 07:17 AM
Thanks TheRealZap
Suppose you're right
I'll have to give it a go and see what happens. I want to try reduce the amount of hardware i have hanging around
#4 Swaartbaard
Swaartbaard
  • 15 posts
Posted 04 November 2013 - 08:51 AM
I realize i've shot the gun here... the UX8 doesn't actually have phono inputs. Only RCA S/PDIF...
Anyone know of a converter that will allow me to connect the converter to the turntable and then converter into the UX8 S/PDIF input??
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 04 November 2013 - 09:16 AM   Best Answer
  • 1
#6 Swaartbaard
Swaartbaard
  • 15 posts
Posted 04 November 2013 - 11:27 AM
Thanks for the help TheRealZap.
I'll let you know what does and doesn't work but worst case scenario I can hook them up directly to the studio monitors using the phono preamp.
Thanks again!
#7 Swaartbaard
Swaartbaard
  • 15 posts
Posted 12 May 2014 - 09:37 PM
I hooked it up to a project phono out and then studio monitors. Worked like charm!
Thanks for the help
Also tagged with one or more of these keywords: ux8, turntable
