Pod Hd500 Latency.
podhd500 windows8 audacity reaper
3 replies to this topic
#1 DjacobCaine
DjacobCaine
  • 2 posts
Posted 05 November 2013 - 09:37 PM
Hey everyone, I just received a PODHD500 in the mail and I'm having a bit of trouble with direct recording. I'm using a Dell with an Intel Celeron with 1.70 GHz, 4 gigs of ram, and windows 8. I dialed in a good djent tone and wanted to test it with a drum track I had in Reaper. I haven't had any latency issues with reaper since I did a system recovery on the computer, hell this morning I was messing around with a djent setup that included about 8 plugins and there were no problems. I attempted to record with the POD and everything seemed to be going well during the recording until I played it back and noticed that my guitar playing was milliseconds off of the actual drum track, I even tried the same thing with audacity and experienced the same issue. Can anybody offer any advice or give me an ultimatum on the situation?
Im running guitar > Pod > Computer Via USB > DAW
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 06 November 2013 - 02:52 AM
What ASIO driver are you using? How are you monitoring your sound?
.... John Lennon
#3 DjacobCaine
DjacobCaine
  • 2 posts
Posted 06 November 2013 - 09:59 PM
WIth reaper I was using the WDM Kernel driver, I set the sample rate to 2x128. With audacity I just had it set to MME.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15918 posts
Posted 07 November 2013 - 06:47 AM
You should be using the Line 6 ASIO device driver. In Reaper, configure your audio system settings to use the Pod HD500 and its ASIO driver as the audio input and output device.
  • 1
.... John Lennon
Also tagged with one or more of these keywords: podhd500, windows8, audacity, reaper
