Alternate Tuning Vs. Virtual Capo
11 replies to this topic
#1 bwnichols
bwnichols
  • 4 posts
Posted 06 November 2013 - 04:17 AM
So I’ve been working with a set of three ‘spider’ capos that can capo individual strings.
Essentially I set the root chord (usually, but not always) of the key as the open strum with the capos, and play rest of chords normally but up the neck – so all transitions to the capo’d chord are ‘nails’ – fast and clean.  Plus it give my hand a break, so I can play for hours without ‘claw-cramping’.
Now envision picking over the top of that open strum … it sounds pretty cool, like rhythm and lead combined.  But I can’t change the chord quickly AND the tuning needs tweaking whenever the capo settings are changed.
What I wish I could do is control (i.e. change) that capo’d chord fast and clean via a foot-operated effects board.  Then I read about some MIDI guitars where actual string tuning doesn’t even matter – and bingo, I realized what I want to do can be done via software and signal-processing only.
But there's problem I see from the 'virtual capo' product description and the Line6 video tutorials I've watched, namely that unless a 'bar' capo is modeled, the 'virtual capo' feature changes the tonal distance between strings -- OK fine if alternate tuning is what you want, but suppose you really don't want to relearn all those 55545 tonal spacing riffs, scales and chords that you already know?
Does the Workbench allow for development of individually capo'd strings, maintaining the stanard tonal distance between strings?  What I would call a 'true virtual capo'.
Thanks in advance...and regardless of the answer, I'll be headed down to my local Guitar Center to check-out these very cool-looking instruments very soon!
#2 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1221 posts
  • LocationUK
  • Registered Products:6
Posted 06 November 2013 - 05:45 AM
Virtual capo changes the open tuning of the guitar.  Which is the most common requirement - so it is almost instant for playing in Drop D or Eb (these are actually preset tunings on a JTV).
What you are asking for is that notes fretted above a certain point on each string play as normal, but that notes at or below that point sound as if they were fretted at that point.
This is an interesting idea (never seen let alone tried a Spider Capo), and one that could potentially be supported on a JTV through a software upgrade if Line 6 choose to try it.  But it isn't how it currently works. It would require that the tuning adjustment per string is dynamically changed (for fretted below the capo point) or switched off (for fretted at or above the capo point).
You could submit this as a suggestion on http://line6.ideascale.com/ but don't hold your breath waiting
#3 bwnichols
bwnichols
  • 4 posts
Posted 06 November 2013 - 12:35 PM
Thanks for your response, Wolf...
For those not familiar with spider capos, and to illustrate that what I'm talking about is really very simple and not beyond the physics of normal guitars, here is my modest setup, capo'd for F-chord:
As the second photo shows, the 3rd fret can still be fingered if needed.  Simply set F, C, G, D, Dm, A, Am, B, E -- whatever you like, then play additional chords and notes in standard positions from the 3rd fret on up.
Unlike many alternate tunings (see 'special case' exception below), chord shapes and scale patterns remain unchanged.
Which is not intended as a knock on the utility or appeal of alternate tunings, just simply to illustrate my hypothesis that in the general case, physics of alternate tunings vs capos is distinctly different.
By inspection I think, these special cases are obviously equivalent:
  • An alternate tuning where the tension in all strings is changed by an equal amount (e.g. Eb 'blues tuning')
        is equivalent to
  • Applying a capo across all strings at the same fret.
        ...regardless of whether the fret is physically above, or virtually (as with Eb tuning) below the nut.
In the general case however, tuning controls the tension of a string and therefore the tonal distance between strings, while capos control where a string is fretted regardless of tension. As the spider capos demonstrate, strings can be physically capo'd independently while leaving the tuning unchanged.
At this point perhaps a YouTube video is in order to demonstrate the usefulness and fun of this idea.
But first I'll need to get my basement studio-pit tidied-up a bit... give me a week or two on that tall order, the maid's been on permanent vacation!
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9061 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 06 November 2013 - 01:08 PM
I understand what you're wanting, but I don't think it would ever be possible unless Line 6 changed the way they handle pitch shifting in the Variax in general. I don't believe the Variax is tracking absolute pitch when it does pitch shifting. All it's doing changing the pitch relative to note being picked up. For what you want to be possible, it would have to track absolute pitch in some way so it could differentiate between the note generated from an open string and a fretted one. I imagine Line doesn't do this simply because doing it would add latency.
#5 bwnichols
bwnichols
  • 4 posts
Posted 06 November 2013 - 02:42 PM
Thanks Phil, for your response...
Understand what your saying about differential vs. absolute pitch, but I really don't think absolute pitch tracking is necessary, and here's why:
Consider the tuning (i.e. tension) of any string, capo'd vs uncapo'd
  • Every note on the fretboard sounds exactly the same, above the capo'd fret.  The capo has no effect on, i.e. is 100% independent of, the tuning (tension1).
  • For any pitch equal to or below the stored value (capo'd pitch), play the stored value.  Just need a differential comparison of the fretted pitch to the stored value.
Seems to me all the signal-processing capability is there -- the hard part is going to be convincing anyone in a position of influence (or capability) that the software development (or demo hack) effort will be worthwhile.
Planning to put some YouTube vids together, but it will be a few weeks...
In practical application, the capos do in fact change the string tension somewhat, sufficiently enough that I generally tune-up whenever changing the spider setup to a different chord.  Envision that Line6 real-time signal processing capability someday will eliminate this nuisance task, providing 'third-hand' real-time chord-changes via footbox, thus freeing the musician's left hand for freestylin'
#6 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9061 posts
Posted 06 November 2013 - 02:55 PM
Well, and I think that's the issue... There's no such comparison being made. The Variax isn't "listening" to the pitch of the note coming from the string in any way. It's just taking the pitch and shifting it by a certain amount. Now, there is some sort of technology for pitch detection in the current algorithm because it detects pitch when you set up a virtual capo. But I don't think it being used at all when the Variax is "live". The Variax is unlike other MIDI guitars in that regard. If your strings are out of tune while playing the Variax while using an alternate tuning, you'll be out of tune. There's no pitch correction going on.
I'm not saying it's impossible altogether. I'm just saying it would involve changing the way the pitch shifting works currently.
#7 bwnichols
bwnichols
  • 4 posts
Posted 08 November 2013 - 03:26 PM
Thanks Phil again for your response, I hear what you're saying and have given it some serious thought.
In the spirit of simplifying programming & signal-processing complexity, wouldn't it be acceptable to play (i.e. when fingered) ALL fretted notes -- below the capo, above and equal to?  So unlike a physically capo'd guitar, the entire fretboard of the virtually-capo'd guitar would be open for fingering?  That's the way JTV virtual capo essentially works now with respect to the fretboard, so the less change to the status quo generally the cheaper and simpler the implementation of a given change, yes?
So if we can agree this is acceptable, then the only condition for playing the stored (capo'd) value would be when the string is vibrating at its lowest (i.e. 'nut') frequency.  Now I'm not an analog signal guy, but enough of an engineer to know that a vibrating string can act as both a signal source and a filter capable of canceling itself out completely.
Run two signals through an analog 'high & low-pass filter' where the threshold values for both high and low pass are set by the string's nut frequency:
  1. Input the string's vibrating frequency through the high pass, and
  2. the string's stored value through low-pass side of the filter.
Output either:
  1. The string's vibrating frequency above, or
  2. the string's stored value, equal to or below the threshold value.
Again, not a signal guy, but this seems like rudimentary electronics compared to what must be going on inside a JTV to provide its amazing capability...
#8 bsbarber73
bsbarber73
  • 5 posts
  • Registered Products:4
Posted 27 July 2014 - 03:14 AM
Hello everyone. I was reading this thread and looking at the spider capo trying to grasp why the variax can't achieve what this thing can. I do not see the limitation here because with a jvt 89 variax you can change the open fretting of any string 1 octave up from the nut to one octave down.It will be less on other modles depending on the amount of frets. Using workbench HD you can set different open tunings for each individual string and save it for a toggled position. This way you can have any tuning and save it as a toggled preset. With a flick of a switch you can change open tuning to what ever you want. You could have three strings one octave up and three one octave down. The possibilities are almost endless.
#9 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1221 posts
  • LocationUK
Posted 28 July 2014 - 04:37 AM
I agree that the possibilities with JTV are quite large, but the spider capo can't be done unless you have a lot of presets to jump between and potentially change preset every time you change chord position as the whole point of them is for open chords and you would need a preset for each combination of open and fretted strings.
The spider capo sets an alternate set of open notes, but everything fretted above the capo will be in normal pitch.  JTV when you change Tuning you change every note on the string. You could simulate a spider capo if you only pitch changed every note below the capo point back to the capo point, but the JTV isn't programmed to do that. As far as I can see the idea never got to IdeaScale.
The Idea of using alternate tunings alone for playing songs is quite an old one, I recall an even older thread from this one
http://line6.com/sup...g-footswitches/ where a character called Merlin said that he would play songs just by using predefined tunings - and that was on an original Variax where you had to dedicate the Preset to the tuning.  To confuse the audience he would drink beer with his fretting hand.
#10 davidb7170
davidb7170
    Gear Head
  • PipPipPip
  • 841 posts
  • LocationDavenport, IA
  • Registered Products:9
Posted 30 July 2014 - 10:37 AM
I've seen the spider capos, and they look like a nightmare to me... I have seen people get really interesting and cool sounds using them, but I've not really ever considered them for my use...
I use the JTV alternate tunings for tones below standard and some other drop such and such (and set up patches in my 500X to force those), but when I need to raise from standard pitch for our singer or such, I just use a standard capo. For those used to using the spider capos, I'd say keep using them on the JTV set to the standard EADGBE or whatever you use with them (which you can set with the JTV forced tunings). You can also use the JTV tuning feature to move up or down to different base keys with your spiders in place.
I think the spiders would require some special techniques, and that if the spider capos were not actually in place would screw up the person used to using them and have to change their technique. On some of the songs I use a standard capo with, If I used JTV forced alternate up-tuning, I would be screwed up, as my points of reference would be shifted.
Just my 2 cents....
Dave
  • 1
Line 6 Gear - Variax 300; JTV-59, JTV-69S, Pocket-POD, POD XTL - (RIP), POD X3L, HD500, HD500X, HELIX
1966 Gretsch Country Gent, 1973 Fender Tele Deluxe, 1978 Strat, 2017 Tele Elite, Epiphone LP Classic, Epiphone Special with P-90's
Gigging Amps: Alto TS210, Alto TS112A, Quilter Tone Block 200, Crown XL1000; Yorkville NX35 Speakers
#11 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1221 posts
  • LocationUK
Posted 31 July 2014 - 03:50 AM
I agree with using a real capo to move up - just to remove the warble.  The only exception is when you need to change tunings mid song which I have had to do for songs like Aqualung as the acoustic is best played capo @ 3rd while the electric is normal.
#12 clay-man
clay-man
    Power User
  • PipPipPipPip
  • 1964 posts
  • Registered Products:3
Posted 31 July 2014 - 04:13 AM
        is equivalent to
A physical capo changes the notes when playing strings open. The Variax capo is just a name they gave their pitch shifting alt tuning functionality because you can move it easily like a capo.
The thing with the Variax capo and alt tunings is that it doesn't change just the open notes, but it retunes the strings digitally. This means that all the frets will play up or down according to the pitch you set it to play.
Example:
say you fret the 5th on the fat E. That's an A note.
fret the 5th on the fat E with a capo on the 3rd fret. It's still an A.
Now, fret the 5th on the fat E when you "capo'd" it in variax 3 frets up. You play a C note now.
You get it?
Your request is impossible.If you want to do what that spider capo does, get the spider capo.
  • 1
For a minute there, I lost myself.
