jdcooley719 Posted November 9, 2013 Share Posted November 9, 2013 Anytime I go to record-enable a track in Pro Tools, or I'm recording a track at all in any other DAW, I get this really awful hissing/static noise in the playback. I thought at first my sample rate's were mixed, but that wasn't the problem. I've had it universally set at 44.1khz and 48khz and both settings yield identical results. I've changed my buffer size to every setting possible, and it doesn't fix the problem at all. The only solution I've had was in Pro Tools, where I enabled the Low Latency Monitoring setting, and in this instance it just doesn't play back my guitar through Pro Tools, it will only play back through the actual device. Any thoughts or ideas? Quote Link to comment Share on other sites More sharing options...
