Studio Pod Ux2 With Nuendo 4 Has Not Enough Inputs
studio pod ux2 inputs nuendo 4 detecting
4 replies to this topic
#1 rzzx24
rzzx24
  • 5 posts
  • Registered Products:1
Posted 09 November 2013 - 11:53 AM
Hi Line6 users and staffers! I'm using my Pod Studio UX2 with Nuendo 4 but I have an outstanding problem. In the Nuendo's VST connection window, the software only detects the mic1 and mic2 input busses. How can I enable the others input entrances like "instrument" or "line1" and "line 2"? The ASIO drivers is Asio4All v2 or Asio UX2.
Thx and keep on rockin' guys!
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17728 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 09 November 2013 - 11:56 AM
you have to use the line6 ASIO driver, and you can change inputs in the control panel of windows there is a line6 audio midi control panel.
#3 BigChas52
BigChas52
    Guru
  • Line 6 Expert
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 09 November 2013 - 12:00 PM
ASIO4ALL is rubbish.  Use the UX2 driver.  As Zap said, make sure that the "Instrument" input is selected in the Line 6 MIDI control panel.  You can probably also get to it through Nuendo's audio options if you dig hard enough.  I can't give you specifics, as I am not a Nuendo user, but I can get to it through Pro Tools, Reaper, and FL Studio.
#4 rzzx24
rzzx24
  • 5 posts
Posted 16 November 2013 - 01:59 AM
Thank you guys! Now the problem is partially solved! Changing the drivers the mics inputs and the instrument inputs works, but I have another question for you: how can I record both inputs, instrument and mic1, at the same time? When I select "Instrument and mic1" from midi device control board, Nuendo only detects Instrument inputs and line1 and line2 inputs, but the bigger problem is in Pod Farm. Why when I select the inputs form the mixer view this happens: If i select on Input1 "mic1", in the Input2 slot there is only "mic2" selectable but if I select "Instrument" for Input1, in Input2 are selectables all the inputs connections of the Pod. Using this method however I have the same rig tone for the device plugged in Instrument (on Input1) and the other one plugged in Mic1 (on Input2)! Please help me, i'm just a little confused about this! Sorry for the big question! :)
#5 BigChas52
BigChas52
    Guru
  • Line 6 Expert
  • 2889 posts
Posted 16 November 2013 - 06:46 AM
Have you read the manual?
