Dt25 And Hd500 - Amp Setings And Precedence
dt25 hd500
3 replies to this topic
#1 drschultz
drschultz
    Iknowathingortwo
  • PipPip
  • 117 posts
  • Registered Products:3
Posted 12 November 2013 - 09:53 AM
Hello all, quick question.
HD500  L6 Linked to the DT25 1x12.  My question is which amp controls take precedence, the HD500 or the DT25?  Example:  If the DT25 gain control is set at 12 o'clock but the gain for the amp on the HD500 is set for 10 o'clock which is the true gain setting?
Thanks!
Dan
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 12 November 2013 - 09:54 AM
it will recall the tone as saved.. after that communication is 2 way... whichever one you turn will work... it won't save unless you press save explicitly...
#3 radatats
radatats
    Power User
  • PipPipPipPip
  • 2323 posts
  • LocationOrange County, NY
Posted 12 November 2013 - 10:38 AM
as TheRealZap said, the POD always takes control when using L6 link.  Once a patch is selected however, either the DT or the POD knobs will affect the signal.  If you make changes using the knobs on the DT and then press save on the POD, those changes are still saved just as if you had done it on the POD.
If you then change patch, any changes not saved are lost and the POD's new settings are applied.
#4 drschultz
drschultz
    Iknowathingortwo
  • PipPip
  • 117 posts
Posted 12 November 2013 - 01:20 PM
Thanks to you both for the fast response.  I am starting to get more into creating more patches for the HD500 + DT25 vs HD500 + PA.
Thanks again,
Dan
Also tagged with one or more of these keywords: dt25 hd500
