4 Cable Method Vs. L6 Link With Podhd And Dt25
7 replies to this topic
#1 STPLE
STPLE
    Iknowathingortwo
  • PipPip
  • 121 posts
  • LocationUSA
  • Registered Products:4
Posted 12 November 2013 - 08:28 PM
Any advice or guidance would be much appreciated.  If this has been covered before I am sorry - I can't seem to find all the old threads.
I absolutely love the DT25.  I love the tones and flexibility.  Here is my setup.  Currently I have a PODHD500 and use the L6 Link to connect to the DT25 (head and cab).  I have not updated the DT25 to 2.0.  It still has the original firmware.  I use a XLR out of the DT25 to PA/House (I don't mic the cab).  The amp is setup on stage with an attenuator.  I use the amp as my own personal monitor for my guitar.  The master on the amp is usually stays put at around 2 o'clock.  This is a church setting so a typical set will range from very clean warm tone all the way to very aggressive crunch and/or distortion.  I usually use two or three amp models (usually 4-5 different tones with different delays, etc.) for each set.  (By the way, I have been able to control the volume between patches very successfully - with time, patience and help from other forum members it can be done).  I play an American Strat with humbucker pick ups.
Here is my question.  Would it be worth trying out the 4 cable method and not using the L6 Link??  I have heard others comment that they think the amp sounds better going direct into the amp.  Would it be worth trying out (borrowing cables, updating the DT25 firmware, getting a MIDI device, readjusting patches, etc.)??
Kinda an open ended question.  Just looking for those who have tried both methods and what you thought - or if you noticed a difference at all.
Thanks in advance.
#2 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 12 November 2013 - 09:25 PM
been there done that, definitely not worth it... do the firmware updates but use the L6 link. my opinion anyways...
#3 mqueluz
mqueluz
  • 47 posts
  • Registered Products:1
Posted 13 November 2013 - 03:51 AM
You don't need the 4cm to try this, just plug your guitar directly to your amp.Does it sound better? Does it feel better? I guess that would answer your question :) In my case, I prefer the sound of the amp and I'm going 4cm all the way, but I'm in the minority side.
#4 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
Posted 13 November 2013 - 04:29 AM
Here is the only thing that can be different by not using the L6 link.  You can keep your POD set to Studio Direct and you can use your dual amp patches, even though they get summed to mono in the end.  The preamps in the DT are EXACTLY the same as in the POD so there is NO benefit whatsoever to the 4 cable method except to limit your options and create a messy setup.
Using the L6 link switches your POD to Combo/Stack depending on what you have and configures the power section accordingly.  By going straight into the FX Return however, you can just use the power amp section and your cab and keep the POD in Studio Direct.  All your patches stay the same, you are just using the tube power section to drive your cab.  You can still manually change the topography, Class A/AB and Triode/Pentode.
Is it worth it?  Try it and see for yourself but I definitely think 4 cable with a DT is a complete waste of time.  I've tried it and you gain absolutely nothing.  Straight to the FX Return at least has a logical possible difference.
Edit - after careful thought, there is one scenario where 4cm could benefit.  By using the preamp in the DT you free up a lot of DSP in the POD for FX use if you really need a FX heavy patch.
  • 2
#5 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
  • Registered Products:2
Posted 14 November 2013 - 05:27 AM
The fx send and return on the pod are noisy and drop the gain a bit. Avoid them unless you have a strong need for pod fx in the amps loop
#6 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2328 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 15 November 2013 - 02:06 PM
I've been playing through a DT50 Head plugging the HD500 directly in the front using Stack Front setting and it sound pretty good to my ears. I'm going to try other ways down the line but I'm going to enjoy it like this for now.
#7 STPLE
STPLE
    Iknowathingortwo
  • PipPip
  • 121 posts
  • LocationUSA
Posted 21 November 2013 - 08:49 PM
Thanks guys. I appreciate the feedback. I haven't played it direct since the day I bought it. I like the way it plays and sounds now so I'll just keep going as is and not mess with the 4cm.
Radatats you mentioned doing the firmware update. If the HD 500 is up to date - what is the benefit of the amp update??
Thanks again.
#8 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
Posted 21 November 2013 - 09:43 PM
No point in upgrading the dt if you are using pod and line6 link, you already get the same functionality via the pod. The update is useful for those using 4cm or without a pod.
