Samoon8 Posted November 14, 2013 Share Posted November 14, 2013 I'm having that delay problem when I connect my Pod hd pro direclty into my computer and its worked before recently but I don't remember how I got it to work. Now I can't seem to figure it out so I just figured I would download or update audio drivers so I can get rid of the delay. Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 14, 2013 Share Posted November 14, 2013 Use the Line 6 driver. Monkey will help you download and install or reinstall it. Remember that once you connect your HD Pro to your computer it will become your audio card. Connect your speakers/headphones to your HD Pro outputs. Turn off the monitoring feature in your DAW; that is usually what's responsible for latency (the delay problem). Another potential cause is the size of the audio buffer your computer uses; again, the Line 6 driver allows you to control this using the Line 6 Audio MIDI Devices control panel. Experiment with different settings. Quote Link to comment Share on other sites More sharing options...
Samoon8 Posted November 14, 2013 Author Share Posted November 14, 2013 @Uber Guru Hey bud! I just connected the speakers from the output which worked. Now I just need to get the audio from my computer. I see on my sound settings that there is audio but I can't hear it :( Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 14, 2013 Share Posted November 14, 2013 Go to your computer's system sound settings (Control Panel on PC; System Preferences on Mac) and assign the Pod HD Pro to be your computer's soundcard. Also, in the Line 6 Audio MIDI Devices control panel, you may need to adjust the Hardware Monitor slider to increase the monitoring level. Quote Link to comment Share on other sites More sharing options...
Samoon8 Posted November 14, 2013 Author Share Posted November 14, 2013 Thanks! I appreciate all the help! I got it to work but now I have this nasty reverb. I didnt add any kind of reverb because every patch I cycle through has this reverb to it. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted November 15, 2013 Share Posted November 15, 2013 perhaps turn monitoring off in your daw? Quote Link to comment Share on other sites More sharing options...
