Setup Troubles
hd500x
Best Answer radatats , 16 November 2013 - 04:15 PM
Make a new patch in an empty slot with no FX, just an amp, any amp, don't change anything, strictly default.  Guitar in to POD, left 1/4 out to the Peavey channel A input. Make sure you are plugged into the outer Neutrik connectors not the two center 1/4 jacks.  Peavey channel A out to Blackstar cab.  Check to make sure the Circuit Breaker on the back of the Peavey is not tripped, reset it if it is.
POD Master full clockwise, Peavey channel A volume 1/2, channel B volume off.  By the pedal on the POD, GUITAR IN  to Normal, 1/4 OUT to Line.  Guitar Volume 1/4 and see what you got.  You should definitely have sound now.  If nothing, turn Peavey off and switch to Channel B and see what happens.
If still nothing, plug your guitar straight in to the power amp and see if there is sound.  Keep the guitar volume low and amp volume 1/2 at first so you don't damage anything.  Turn guitar volume up slowly. Check both channels.
Let us know how this works and we can go from there.
Go to the full post
16 replies to this topic
#1 GRLidstone
GRLidstone
  • 11 posts
  • Registered Products:1
Posted 16 November 2013 - 06:23 AM
I've only recently purchased my 500x and I've got my rig connected in what I believe to be the correct input/output setup but I'm having no joy in getting any sound out from my guitar.
My rig is the 500x runninh from the 1/4" l/mono output into a Peavy IPR 1600 power amp input and that is connected to a Blackstar cab.
Any ideas as to where I'm going wrong?
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16066 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 16 November 2013 - 06:47 AM
First, I would make sure you're getting sound into the device. Try the tuner. Does it work? Note that it only works with Input 1, so make sure your preset is set to include guitar in input1.
Then try using headphones connected to the HD500x. Are you hearing your guitar?
Let us know the results of these tests and we can go from there.
.... John Lennon
#3 GRLidstone
GRLidstone
  • 11 posts
Posted 16 November 2013 - 07:44 AM
The tuner works fine. I can't test the headphones. No adapter for them.
#4 ext1jdh
ext1jdh
  • 97 posts
  • Registered Products:2
Posted 16 November 2013 - 07:55 AM
It's basically plumbing. Follow the signal chain until it stops working. You're getting the tuner so you know the connection from guitar to pod input is working.
Guitar to pod input. The pod input can be set up to only accept variax, or 1/4 or aux. make sure in the setup page of the pod.
Pod signal chain set up correctly? If you have an effect loop in your chain it needs to be connected (if the loop is there but nothing plugged in, your signal will never get through).
Pod mixer set up correctly. If you're using the left 1/4 out. Make sure the left channel volume is up.
Also check your right channel.
Ensure the pod is set up to output to amp or line, depending in your setup.
You don't have a headphone adapter, but you can use a regular 1/4 cable into your external amplifier. Should function the same.
#5 GRLidstone
GRLidstone
  • 11 posts
Posted 16 November 2013 - 08:24 AM
I've checked the inputs and its accepting Guitar, Aux and Variax. From there afterwards I have no clue what I'm looking for.
#6 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16066 posts
Posted 16 November 2013 - 10:25 AM
Not trying to be jerky.... But have you read the manual?
.... John Lennon
#7 GRLidstone
GRLidstone
  • 11 posts
Posted 16 November 2013 - 10:32 AM
I did yes. Still having no joy though. A friend and I worked out the problem was something to do with the 500x that's the only place the signal is getting lost.
#8 ext1jdh
ext1jdh
  • 97 posts
Posted 16 November 2013 - 12:45 PM
do you have an FX loop module in the chain?
#9 GRLidstone
GRLidstone
  • 11 posts
Posted 16 November 2013 - 12:48 PM
Yeah, I built my presets before I got the power amp and cab without a way to test them. Is this what your getting at? This is my first time with this sort of thing.
#10 GRLidstone
GRLidstone
  • 11 posts
Posted 16 November 2013 - 01:20 PM
I think I've narrowed the problem down to my output. I can't understand what's wrong but the guitar input is fine it's just the signal isn't transferring to my Power Amp.
#11 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 16 November 2013 - 04:15 PM   Best Answer
#12 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16066 posts
Posted 16 November 2013 - 05:19 PM
Get or borrow a pair of headphones or adapter. Knowing whether you are getting a signal from the headphones will be very useful debugging info at this point.
.... John Lennon
#13 ext1jdh
ext1jdh
  • 97 posts
Posted 16 November 2013 - 07:28 PM
Is there something plugged I to your physical effects loop on the pod?
With nothing physically plugged in, the chain is broken. Nothing will get to the output, because there's nothing in the loop.
#14 GRLidstone
GRLidstone
  • 11 posts
Posted 17 November 2013 - 02:37 AM
Okay all that effort and the only problem was the volume? God damn it.
#15 radatats
radatats
    Power User
  • PipPipPipPip
  • 2326 posts
Posted 17 November 2013 - 08:56 AM
We've all been there at one time or another... glad it works! :D
#16 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16066 posts
Posted 17 November 2013 - 09:11 AM
I remember once spending several hours trying to figure out why my x3 Live had suddenly stopped working. No sound output yet I had changed nothing, I thought. Then I remembered I had just cleaned the unit with a combination of vacuum cleaner brush and dry cloth wipe down. In doing this I apparently moved the Line/Amp switch to a midpoint position, engaging neither the Line nor Amp outputs. I had surprisingly discovered a device mute switch! Moved the switch and presto - working again.
.... John Lennon
#17 GRLidstone
GRLidstone
  • 11 posts
Posted 17 November 2013 - 02:06 PM
Thanks the help anyway guys.
Also tagged with one or more of these keywords: hd500x
