Pod Farm Is Not Working With Fl Studio
pod farm farm fl studio pod studio gx gx
4 replies to this topic
#1 FinInfinite
FinInfinite
  • 2 posts
  • Registered Products:1
Posted 16 November 2013 - 08:46 AM
So, I use FL Studio a large amount, and I wanted to record a guitar line.  I knew that my brother owned a GX (and a guitar, and POD Farm), and after discovering that POD Farm comes in VST-form as well, I was ecstatic.  I immediately placed the VST onto FL Studio after I had sorted out some problems with not being able to detect input into the normal POD Farm.
Having set up everything correctly (to my knowledge), I tested it out, and, lo and behold, I could hear input from the GX into the mixer and out through the master, but it was as if the sound passed right through the POD Farm without anything happening to it.  The Input and Output monitors did not spike when I played, and no effects (e.g., amp, distortion, EQ, etc.) changed the sound.
So, to quote Derpy Hooves, "I just don't know what went wrong!"
Can anybody help?
#2 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 16 November 2013 - 09:31 AM
1.  Make sure you have selected the GX ASIO as your inputs.
2.  Use one button recording to record directly to a track, or to record to the Edison editor (your choice).  Once recording is finished, reassign it from the "REC" track to one of your inserts.
Do not use the plug-in until after your recording is done.  It is for post processing.
#3 FinInfinite
FinInfinite
  • 2 posts
Posted 16 November 2013 - 09:58 AM
My selected soundcard is ASIO GX, and the input to Mixer Track 1 is the stereo guitar input. (Although it's actually two of the same mono track, but whatever)
I'll show you in a screenshot. https://drive.google...dit?usp=sharing
#4 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 16 November 2013 - 12:10 PM
Don't open POD Farm in FL Studio until AFTER you have recorded your track.  Record the track dry and then add the POD Farm plug-in as an FX.
If you use FL Studio "a large amount" surely you must know how to record audio :)
#5 prashant201185
prashant201185
  • 1 posts
Posted 12 September 2014 - 12:11 AM
correct bravo
Also tagged with one or more of these keywords: pod farm, farm, fl studio, pod studio gx, gx
