Open My Patches From X3live Without Conect!
10 replies to this topic
#1 esaupro
esaupro
  • 16 posts
  • Registered Products:2
Posted 18 November 2013 - 08:07 PM
I changed the X3 Live for HD500X but i cant load my patches, i have no more hte X3 Live, is there a way to open my Patches  without conect the Pod X3 Live? just for see my tones. thanks!
#2 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 18 November 2013 - 08:20 PM
Try dragging the X3 tones into HD Edit. The Real Zap is right, it won't work. I should've tried it first. You could open your tones in Gearbox and then get a look at what your settings were and then try recreate them.
Added: Darn I should have tried that first too, LOL. Sorry. I just checked they are all right, it can't be done, I just tried it. I guess that's another reason for me to keep my X3 Pro and UX2.
#3 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 18 November 2013 - 08:40 PM
Can't be done.
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 19 November 2013 - 04:55 AM
....You could open your tones in Gearbox and then get a look at what your settings were and then try recreate them.
No, this won't work either. Gearbox does not open or load tones without the X3 connected.
.... John Lennon
#5 esaupro
esaupro
  • 16 posts
Posted 19 November 2013 - 06:33 PM
and there is not a solution for this problem'? do i cant re open again my presets  from the x3? , i have effects that i dont remember how to re make :s
  • -1
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 19 November 2013 - 06:39 PM
the solution is plug in an x3... noone said it was a cheap solution....
besides the effects are all completely different and sound completely different....
the cheap solution is to use your ears and get started.
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 19 November 2013 - 06:41 PM
The problem is you no longer have your X3. One solution is to get another one. A better solution is to start using your HD500x.
Even if you could see all settings in your X3 presets, you won't be able to manually recreate those sounds in the HD500x using those exact preset/parameter settings. Firstly, many of the X3 amps are not available in the Pod HD. Secondly, the FX modeling technology is totally different; the HD uses the Line 6 M-series FX while the X3 does not. So even the same FX models will sound different with all parameters set the same. Thirdly, the same is true of the amps; the HD uses completely different amp modeling technology so the same amp models (where they exist between the X3 and HD) will sound different with the same parameter settings.
Finally, and most importantly, the Pod HD offers far superior sounds to the X3. You are doing yourself a disservice if your goal is to simply recreate the same sounds you had in your X3. If you simply wanted to keep, or recreate, your X3 sounds you would not have upgraded. You upgraded because you want, and can certainly achieve, better sounds. But the way to do is is not with your X3 presets.
So forget about the supposed problem you are facing. It's not a problem. Learn to use your HD500x - that's where your energy should be going.
.... John Lennon
#8 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 19 November 2013 - 06:42 PM
Sorry, it can't be done without an X3 attached.
#9 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
Posted 20 November 2013 - 11:20 AM
That's a really good comment Silverhead. Thanks I still like my X3Pro though.
#10 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 20 November 2013 - 11:33 AM
That's great. As long as you are happy with your X3 tones there's absolutely no reason to change. Happiness is not getting what you want - it's wanting what you've got.
.... John Lennon
#11 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
Posted 20 November 2013 - 01:03 PM
Oh wait, I have the HD 500 too. I like the best of both worlds.
