Monkey Cannot Update My Hd500
27 replies to this topic
#1 Zombieslayer5P
Zombieslayer5P
  • 49 posts
  • LocationChino Hills, CA
  • Registered Products:2
Posted 20 November 2013 - 05:53 AM
Hey guys.  I'm in a bit of a pinch here.  I'm trying to update my POD with the latest firmware update, but Monkey keeps saying it cannot connect to the server and gives an error code (80001019).  I've heard of people having this problem when it comes to downloading a customtone patch, but I haven't been able to find any info on people having this issue with Monkey simply being unable to fetch an update from the L6 servers.  Is anyone else experiencing this, and if so, have any of you managed to conquer this obstacle?
Thanks for your time in advance, everyone.  :)
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17815 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 20 November 2013 - 05:56 AM
i've seen this issue with satellite internet connections, but i'm sure that's not the only cause.
#3 Zombieslayer5P
Zombieslayer5P
  • 49 posts
Posted 20 November 2013 - 06:07 AM
No satellite connection here.  All cable.
#4 smrybacki
smrybacki
    Gear Head
  • PipPipPip
  • 669 posts
  • LocationCarlisle, PA
Posted 20 November 2013 - 06:19 AM
Could it be the Line6 Servers are temporarily overwhelmed?
However you play music using whatever gear you may choose that day-- the JOY of making it is the heart of it.
#5 Ed_Saxman
Ed_Saxman
    Iknowathingortwo
  • PipPip
  • 256 posts
  • LocationBarcelona (Spain)
  • Registered Products:3
Posted 20 November 2013 - 08:32 AM
Same problem here. Just downloaded the new firmware and updated from file: http://line6.com/software/index.html
Completely irrelevant update, btw.
And, of course, HD500 Edit still crashing on OS X when using the expression pedal for a while (having to turn on/off the whole unit to reconnect). Seems obvious that they are unable to fix this.
#6 hollis1003
hollis1003
    Iknowathingortwo
  • PipPip
  • 469 posts
  • LocationDunedin, FL
Posted 20 November 2013 - 10:53 AM
I'm having the same issue.  Monkey won't connect to Line 6 server.
#7 manchlo
manchlo
  • 1 posts
Posted 20 November 2013 - 02:04 PM
i have the same pb. Monkey can't connect to line 6 server ! (code 80001019)   :(
#8 mrmtdew
mrmtdew
  • 2 posts
Posted 20 November 2013 - 02:25 PM
Same problem...
#9 Metalchef
Metalchef
    Iknowathingortwo
  • PipPip
  • 197 posts
Posted 20 November 2013 - 02:31 PM
Same problem.....
Yes I hear the cries of the carrots.... For it is harvest day and to them it is the Holocaust..... So I say let the rabbits wear glasses....
#10 smrybacki
smrybacki
    Gear Head
  • PipPipPip
  • 669 posts
Posted 20 November 2013 - 03:19 PM
I HAD this problem, then started my browser (Chrome) to check Internet status -- tried Monkey again and success.
FWIW
#11 shockvein
shockvein
  • 2 posts
Posted 29 November 2013 - 02:39 AM
Any ideas how I can reinstall flash on my DT25 when my iMac won't connect to 'Line 6 Server'?
#12 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17815 posts
Posted 29 November 2013 - 07:14 AM
if by reinstall you mean just set the current version back to default... just pinch the pentode/triode switch with the topo switch while powering on...
hold it down until the lights blink and release....
if you mean install a new version... go to the downloads link at the top right and download the file... you can use monkey from the file rather than connecting to the server.
  • 1
#13 shockvein
shockvein
  • 2 posts
Posted 29 November 2013 - 10:36 AM
Thanks so much 'TheRealZap' all working better now. Any chance I could ask you a few more questions, as I'm a novice and you obviously know your stuff,
Im really confused with the new master volume update on PODHd and Dt25. Will the Master on the Podhd affect the tone of the Dt25? Best connection? Low volume amp high volume Podhd or High volume Amp low volume PODhd?
Also what is the best way to level volume of patches without affecting tone, using Pod mixer,channel volume on amp settings page or effects output levels?
And one last thing, full amp models or Pre amps for DT25 connection? Does it really matter?
I would really appreciate any help/advice
Cheers,
Happy Thanksgiving
#14 Metalchef
Metalchef
    Iknowathingortwo
  • PipPip
  • 197 posts
Posted 29 November 2013 - 11:34 AM
I can answer the Pre and Full amp question for you.... Like u said it's all relevant to the user. When in LVM connected to my DT50 2x12 I use full amp models. While in Regular Mode (normal) I use mostly Pre versions excluding the Supro and Fender Deluxe models I use full at all times.
#15 swwood
swwood
  • 12 posts
Posted 30 November 2013 - 08:14 AM
Same here.  Just a week or two ago it was fine.  and my PC works fine too.
#16 Norifume
Norifume
  • 1 posts
Posted 30 November 2013 - 10:52 AM
I have the lollipop same problem....  :angry: (error 80001019) with the line 6 monkey, it can´t connect to the server.
#17 Metalchef
Metalchef
    Iknowathingortwo
  • PipPip
  • 197 posts
Posted 30 November 2013 - 01:43 PM
I got the same code. Use the UPLOAD FROM FILE tab and follow the instructions. Worked 2nd time in tried.
#18 fearmore
fearmore
  • 16 posts
  • Registered Products:4
Posted 30 November 2013 - 04:50 PM
Can't get to the server, either: error 80001019.
#19 beauholland
beauholland
  • 1 posts
Posted 01 December 2013 - 01:18 PM
same problem when trying to update Tyler Variax firmware.
#20 Smiz86
Smiz86
  • 4 posts
Posted 01 December 2013 - 01:38 PM
Just started getting this error yesterday... Uninstalled everything and reinstalled Monkey/License Manager, License Manager has no trouble connecting to the UX2 device I have and verifying the license, but Monkey can't find it nor can it connect to the line 6 web server giving me error code 80001019. I'm on the internet now obviously, so it isn't my internet connection!
#21 roccobass
roccobass
  • 1 posts
Posted 01 December 2013 - 01:47 PM
Thanks for the posts from you guys showing it seems to be widespread. Just trying to sign on period.
Thinking, "what kind of monkey-business is this?"
I was going "ape" trying to connect, reconnect and restart my Mac.
I'm using 10.9 incidentally. Guess I'll try again tomorrow
#22 dsthomas
dsthomas
  • 2 posts
Posted 01 December 2013 - 05:15 PM
Add another to the mix. Can't connect
#23 sonicdeviant
sonicdeviant
  • 2 posts
  • LocationYorktown, VA
Posted 02 December 2013 - 06:03 AM
Same here.  Mac on Mavericks.  Suddenly Monkey v165 can't connect (Code 80001019).  Worked fine up until a few weeks ago.  Maybe Mavericks update?  Seems to sign in to the account fine but just can't check for updates.  Last successful check for updates was before the v2.2 firmware for HD 500.  Everything else shows the latest version, so this was a sudden, inexplicable error.
#24 guitarno
guitarno
    Iknowathingortwo
  • PipPip
  • 223 posts
Posted 02 December 2013 - 06:20 AM
I have not been able to connect for the last week. I also just went to "Line6 Ideascale" and that's down as well.
I just opened up a service ticket for this. Don't know if it's the right way to address this or not, but I don't think we can count on Line 6 scouring the forums to find out about this. I will post something when I get a response.
#25 stusutherland
stusutherland
  • 1 posts
Posted 29 September 2014 - 06:41 PM
Any response to this problem?
#26 dachrab
dachrab
  • 6 posts
Posted 11 March 2015 - 04:03 PM
Add one more to the team.
#27 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17815 posts
Posted 11 March 2015 - 04:13 PM
this thread is a year and a half old....
you can't rely on this being the same issue...
if you're serious about getting help with your current issue... contact support.
http://line6.com/company/contact/
#28 dachrab
dachrab
  • 6 posts
Posted 11 March 2015 - 04:16 PM
I will, but I'll also point out the last response on this thread wanting a solution to the problem was Sept/14.
