Fx Loop. Is This A Bug?
Inerzia
Shouldn't the Fx loop block cut all returning audio when it's switched off?
Well, it doesn't. When off, It prevents audio from being sent, but not from being returned,
which, in most cases, can be enough, but when there's a rather noisy processor in the loop,
the floor noise stays.
Should I open a support ticket about this?
this is not a bug.
When the TRAILS setting in the setup menu is set to ON then the return of the FX-loop is not muted to allow the effects to ring out.
Setting this setting to OFF should mute the return when the FX-loop is off.
