Akg C747 With Line6 Transmitter
5 replies to this topic
#1 bendtaaen
bendtaaen
  • 11 posts
Posted 24 November 2013 - 01:45 PM
Previously i have replaced the connector on a Sennheiser 908 sax  mice to Work with the Wireless transmitter - With success.
Now I woukd like to do the same with my AKG c747 Microphone. I see it has a different OHM ing than the Sennheiser.
Can this be done and how?
Greetings and thanks in advance.
Bendt Aaen
#2 dboomer
dboomer
    Line 6 Staff
  • Moderator
  • 2524 posts
Posted 24 November 2013 - 03:04 PM
The impedance won't be an issue. But it appears this mic requires phantom power. Wireless beltpacks do not supply phantom power but rather they supply bias voltage. So you will either need to find a wireless version of this mic or use an external power supply before going into the beltpack.
#3 RonMarton
RonMarton
    Power User
  • Line 6 Expert
  • 1276 posts
  • LocationSydney, Australia.
Posted 24 November 2013 - 09:28 PM
I regularly use my two AKG C747 microphones via a pair of TBP12 beltpacks, but there are two things to note:
  1. As Don says, I power them externally and
  2. The earlier version that I own (not the current V11) is far more susceptible to induced RF, be that from things like mobile phones, or from an XD-V beltpack, whenever either are close to the "barrel" of the (otherwise superb) AKG mini shotgun.
Sadly, I only know of ONE maker that builds fine sounding and compact battery phantom supplies that are rugged enough for "the road", with battery lives long enough for my gigs …and that's Deneke of the USA.
They have two versions, being their PS-1 (pictured) that powers a single mic, or the slightly more expensive PS-2 that's the same small size, but is able to power a pair of 48 volt condensers, even a pair of my current-sapping large diaphragm Neumanns.
Hopefully, the outlet I've linked below can ship to your location, but if not, you may need to use (and pay for) a forwarding agency, such as http://www.myus.com, if you cannot locate a supplier in your area.
http://www.bhphotovi...ble_Single.html
http://www.bhphotovi...table_Dual.html
#4 bendtaaen
bendtaaen
  • 11 posts
Posted 09 December 2013 - 08:11 AM
I have bought another 908, but I Canterbury seem to find the Worning diagram as I did before Wihre the ristorno Darwin in.
Can you advise.
Bendt
#5 bendtaaen
bendtaaen
  • 11 posts
Posted 09 December 2013 - 08:15 AM
With the resistor in
#6 RonMarton
RonMarton
    Power User
  • Line 6 Expert
  • 1276 posts
Posted 09 December 2013 - 01:44 PM
I'm guessing that what I think you probably used last time is the information you are looking for again, Bendt...
Pin 1:   Outer "shield" or "GND" from microphone,
Pin 2:   1kΩ resistor to both microphone's nominal "+" or "hot", then shorted to
Pin 3:   Signal "+" or "hot" into beltpack transmitter, with
Pin 4:   Not used.
It comes from here: http://line6.com/sup...phones-faq-r230
