No Volume In Topology 3 After Repair For Technical Bulletin 059
dt50 059 bulletin
3 replies to this topic
#1 BlueD
BlueD
  • 19 posts
  • LocationSan Bruno, CA
  • Registered Products:2
Posted 11 May 2013 - 04:49 PM
I brought my amp to service after receiving the notification for the Technical Bulletin 059 from line6. I brought it to King Amplification of Santa Clara, California, and when I went in to try the amp again, the topology 3 of the amp didn't work anymore.
They didn't tell me anything about it before I went in and I'm pretty sure they didn't even bother to test the amp when they put it together after the service... they asked me money to diagnose the problem on the spot (you need very, very big balls to ask money to diagnose an amp you just broke).
Anyways, anybody knows if servicing the amp could lead to that kind of problem, or what could be the issue? A loose cable, a valve that came off the socket... anything else?
If it's something easy to fix I would like to do it myself (I'm an engineer, although I different kind of engineer...).
thanks everybody!
#2 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5240 posts
  • Registered Products:6
Posted 13 May 2013 - 11:47 AM
You might try going through the topography combinations on the working NFLs....Class A, AB, Pentode Triode....If all the combinations work on NFL1,2 and 4....then I tend to think that would eliminate tubes as a culprit...I do think that you should contact Line 6 directly by telephone and inform them about this...That just doesn't seem like things went like they should have...
#3 theoptimizers
theoptimizers
  • 89 posts
  • LocationSouthern California, USA
  • Registered Products:5
Posted 22 May 2013 - 10:39 PM
You might try a Factory Reset.
Factory Reset Procedures in this Document:
http://line6.com/med...evA_English.pdf
I'm pretty sure the difference in "Topologies" is implemented similar to a digital bank switch.
After the reset, use one of the outstanding DT editor programs, to check the settings.  Try different settings as Space suggested, just to see if these make any difference.
Livin' the Dream - DT50 / JTV-59P / HD500
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17696 posts
  • LocationClemmons, NC USA
  • Registered Products:16
Posted 23 May 2013 - 10:20 AM
In all honesty, It sounds like it needs a return trip to the service center. There are a number of things that need checked after servicing and perhaps one got missed.
Also tagged with one or more of these keywords: dt50, 059, bulletin
