Korean 59 Switch
4 replies to this topic
#1 diggerbarnz
diggerbarnz
    Iknowathingortwo
  • PipPip
  • 276 posts
  • Registered Products:5
Posted 11 May 2013 - 06:03 PM
So what IS the issue most had w/the pup switch - today I picked mine up & the modelled guitars are fine but playin straight the 3 way is noisy as F -$%^ just touching it creates noise
I did create a ticket
I see now others issues - really its ok w/modelled sounds - I hope its just a matter of a cleaning
#2 stevef1
stevef1
  • 52 posts
  • LocationUk
  • Registered Products:2
Posted 12 May 2013 - 05:05 AM
Mine did that just used switch cleaner an it's back to normal :-)
#3 BigChas52
BigChas52
    Guru
  • Line 6 Expert
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 12 May 2013 - 05:23 AM
Switch or contact cleaner is probably the best fix for this, but just about every guitar I've ever owned has had a noisy switch at one point or another.  Another fix is to rapidly take the switch through it's positions until the crackle stops.  This wears off the tarnish that is preventing proper contact.
BTW, the same thing will happen from time to time with the volume and tone pots on guitars.  The fix is the same, either carefully spray them with contact cleaner, or just roll them back and forth rapidly until the noise goes away.
#4 diggerbarnz
diggerbarnz
    Iknowathingortwo
  • PipPip
  • 276 posts
Posted 12 May 2013 - 03:47 PM
another dumb question - You guys open up the back to spray it or just spray in front?
#5 anthonylee
anthonylee
  • 50 posts
  • LocationIsrael
  • Registered Products:3
Posted 14 May 2013 - 01:03 AM
Front!  & cover around the switch with cloth & flick the switch between positions.
use Deoxit contact cleaner.
Never had this problem on my JTV 59 but on many Guitars the switch becomes noisy. Just a case of cleaning the contacts.
