Pod Hd500x Not In Device List Of Line6 Monkey
line6 monkey pod hd500x
Best Answer rfriedric , 25 November 2013 - 04:08 PM
Sorted,
I connect via my mobile to internet and it directly worked.
There must be an issue with the firewall in the hotel where I'm currently at.
So thats resolved.
Cheers!
Go to the full post
7 replies to this topic
#1 rfriedric
rfriedric
  • 3 posts
  • Registered Products:1
Posted 25 November 2013 - 02:59 PM
Hi all,
I have problems to connect via Line6 Monkey to my POD HD500X. I can't select the Device from Drop Down List because it's not listed.
I tired it Monkey 1.65 and 1.63 both same issue.
I installed the latest SW and drivers and also the Editor work fine.
Screenshot is attached showing no HD500X in List.
Anybody had similar problems?
@ POD HD500X Flash FW 1.00 USB FW1.01 installed
Thanks for support!
Cheers!
  • -1
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 25 November 2013 - 03:11 PM
Does Monkey recognize the HD500x when it is connected via USB? When connected, you should not have to choose it from the list.
.... John Lennon
#3 rfriedric
rfriedric
  • 3 posts
Posted 25 November 2013 - 03:30 PM
no it seems it's not supported. I installed 1.64 in the meantime to check it.
I found the Log file where I played with it, so some may will be useless but that doesn't look good to me :Created Monkey device: POD HD500X Device not supported.Request error from packet: 6
- Monkey started: Tue Nov 26 00:21:20 2013
Line 6 Monkey
1.64
Copyright © 2003-2013
Line 6, Inc.
Windows 7
Downloading config file: http://line6.com/dis...7&page=releases
Redirecting to: http://line6.com/get...omer&os=Windows 7
Loading server XML
XML Load failed!(Code 80001019) Unrecognized file type.
Loading local config file: C:\Users\friedric\AppData\Roaming\Line 6\Line 6 Monkey\default.cfg                     That file doesn't exist in the folder
Loading config file from resource: C:\Users\friedric\AppData\Local\Temp\l6mF979.tmp
Creating Camel system with timeout of: 60
Attempting previous user: User=rfriedric ID=f9f0d9d3b1a41ced57241a2a7c3d00d7
Sockets: Timed out.
Request error from packet: 0
Previous app device found: connection=0 in= out= id=4294967295
Trying MIDI Query: Out=L6DM@Line 6 POD HD500X@Variax In=L6DM@Line 6 POD HD500X@Variax
MIDI dev inquiry failed to find anything on USB device.
Forcing MIDI product ID:1310722
Device: POD HD500                          i tried to select HD500 to get into the program Window.
Attributes:
   Uses AC Power
   Using Forced Connection
   Supports Add-ons
   Has ESN
   Supports flash memory updates over USB
USB Connection Info: None
MIDI Connection Info: None
ESN: 00000000
USB Firmware Version: 0.00
Comm Error: (Code 00000000) Success.
Scan for devices button pressed.
Device: POD HD500
Attributes:
   Uses AC Power
   Supports Add-ons
   Has ESN
ESN: 00000000
Pinging server...
Sockets: Timed out.
Request error from packet: 1
Disconnected with packets pending. Attempting retry.
Retrying packet....
L6CamelSystem::ErrorMsgHandler got error message to process....
HTTP disconnect error received on network error handler. Retrying packet.
Done processing error message.
Login button pressed.
Attempting user login: User=rfriedric
Request error from packet: 3
Forcing MIDI product ID:7340033
Device: Variax USB Interface
Attributes:
ESN: 00000000
Pinging server...
Request error from packet: 5
Forcing MIDI product ID:196614
Device: Bass PODxt
Attributes:
   Uses AC Power
   Supports Add-ons
   Has ESN
ESN: 00000000
Pinging server...
Monkey ended.
#4 rfriedric
rfriedric
  • 3 posts
Posted 25 November 2013 - 04:08 PM   Best Answer
Sorted,
So thats resolved.
Cheers!
#5 ShawnHeld
ShawnHeld
  • 2 posts
  • Registered Products:9
Posted 11 January 2014 - 06:22 AM
Line 6 has not added any real support. Strange this is not addressed.
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17844 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 11 January 2014 - 06:33 AM
problem is long corrected... if you want support, i suggest contacting support:
http://line6.com/company/contact/
#7 chrisrcarlson
chrisrcarlson
  • 2 posts
  • LocationPortland, OR
  • Registered Products:2
Posted 29 December 2014 - 11:55 PM
What was the solution to this problem?
#8 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
Posted 30 December 2014 - 05:49 AM
The solution is highlighted at the top of the thread.
.... John Lennon
Also tagged with one or more of these keywords: line6 monkey, pod hd500x
