Humming In Standby Mode
dt 50 sound
19 replies to this topic
#1 casparello
casparello
  • 43 posts
  • Registered Products:3
Posted 12 May 2013 - 05:53 AM
Why is my DT 50 humming in standby mode? Yes, I know its a tube amp ... but this constant humming is really something. Wow!
#2 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 12 May 2013 - 06:45 AM
Could be a problem with the amp, but sometimes an amp will not play nicely with the electricity in your house, or at a particular venue, thus resulting in hum or buzz.  Sometimes an amp will not play nicely with another device on the same circuit that is causing electrical interference.  Have you tried the ground-lift switch?  Have you tried different outlets in different parts of your house?  Have you tried it in another house or place?
#3 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 12 May 2013 - 07:21 AM
i think you should have little to no noise in stby. did this happen gradually or suddenly? is the noise present when the amp is on? when did you buy it?
I'M SO HAPPY!
#4 geppert
geppert
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationWest Coast, Canada
  • Registered Products:7
Posted 12 May 2013 - 09:00 AM
Not that this is the answer to your specific current problem (and it shouldn't be humming in standby mode) but I ALWAYS use an AVR whenever I play anywhere including home. I followed another member's (Spaceati) advice and got the Tripp-Lite LC1200. Killer. Never have a hum, never have a problem. As Space also mentioned in one of his posts, these amps are like little CPU's with power tubes .... they can be very susceptible to line voltage fluctuations and bad grounding. Let us know if you figure out the problem. Curious.
  • 1
#5 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5349 posts
  • Registered Products:6
Posted 13 May 2013 - 11:33 AM
wassup fellas...+1 geppert...AVR...Never run gear without it...That lack of hum is just one of those isolation benefits of putting a tranny on your input power...
#6 casparello
casparello
  • 43 posts
Posted 15 May 2013 - 04:36 AM
Thanx again everybody for your support,
AVR -> shure thing. I use a Furman M-10 E
But none of your suggestions really turned out to help my DT 50 (built August 2010).
I just sent it back to Line6/ my dealer (www.thomann.eu) to have this fixed. Hopefully the amp is back soon.
I like the DT so much. The only thing thats missing is an already built locker to protect the amp against unauthorized use.
I´ll keep you posted.
#7 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5349 posts
Posted 15 May 2013 - 09:46 AM
Furman M-10 is NOT an AVR...conditioner only...You have never had the benefits of an AVR with that device. just surge protection and some filtering...Zero Isolation.
Furman AVRs generally have AR in the model...and they cost 2-4 times what the conditioners cost.
120v http://www.furmansou...v=01&id=AR-1215
240v http://www.furmansou...03&id=P-1400ARE
#8 casparello
casparello
  • 43 posts
Posted 16 May 2013 - 11:11 AM
http://www.furmansou...=03&id=AC-210AE :-))
Can be placed in the back of the combo :-)
I can´t see the benefit of the AVRs (extra: isolation) in EU with constant 240v all over the place.
Maybe it´s good to have in the US where chances are high not to get solid 120v ...
#9 bribrew1968
bribrew1968
  • 20 posts
  • LocationTampa, Florida
Posted 24 May 2013 - 09:25 AM
I had horrible humming from my DT50 212.  Turned out to be the power strip.  Changed to another wall outlet and it was fixed.  In standby I never had the issue.  Hopefully they can fix your amp ... these are sweet amps .... best of luck!
Bribrew1968
XBL: AntiHero
2004 American Les Paul
1996 American Stratocaster Plus
2011 HD500 > 2013 DT50 212
#10 Rowbi
Rowbi
    Uber Guru
  • 8258 posts
  • LocationCambridgeshire, UK
  • Registered Products:20
Posted 01 June 2013 - 10:52 PM
I've had several Marshalls and my 6505+ all hum on occasion when in standby, and its usually caused by shoddy power quality in nasty gig venues.
But if it happens all the time in outlets that don't cause other amps to hum, then it may be a fault though.
Just wanted to suggest that in case you don't have an AVR to hand, but they're a good long term investment if you value your gear.
Cheers
Rowbi
Regards
Rowbi
www.rowbinet.co.uk
#11 thatoneguy759
thatoneguy759
  • 17 posts
Posted 02 June 2013 - 08:46 AM
would a ups work too?
#12 lef38
lef38
  • 44 posts
Posted 03 June 2013 - 04:47 AM
I had the same problem and fixed it with this voltage regulator:
http://www.infosec-u...rs/r1-1200.html
(seems to be distributed in France only)
#13 casparello
casparello
  • 43 posts
Posted 24 June 2013 - 01:03 AM
Cheers
Rowbi
hey rowbi,
good advice for the power supply network in the us
over in europe you get constant power supply everywhere.
#14 casparello
casparello
  • 43 posts
Posted 24 June 2013 - 01:24 AM
The journey continues: I sent the humming amp back in may. Line6 in Germany decided without notice to change the tubes, they checked the amp and returned it. I was surprised that they charged me for this.
I went for a testdrive right that evening (... amp still humming like I sent it ...) and just five minutes later the amp started humming louder and louder and ... vaporized. Wow! :mellow:
I returned the amp the next day.
Line6 told me: "The amp has been tested and checked before return.
We can fix it again but the amp is not in the two years warranty any longer so it´s not a Line6 problem."
I assume they checked the amp and switched channel A and B while playing. But when you have a HD500 connected (via L6) the reconfigurable analog components (Class A/Class AB; Pentode/Triode) do change too.
I wonder if they checked on this as well and maybe thats exactly why the amp broke down.
Or do I have one of these DT50s that explode?
#15 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 24 June 2013 - 01:44 AM
is the amp still humming? i think the transformer was going bad and finally fried.
I'M SO HAPPY!
#16 casparello
casparello
  • 43 posts
Posted 24 June 2013 - 06:41 AM
yes
#17 Rowbi
Rowbi
    Uber Guru
  • 8258 posts
Posted 24 June 2013 - 11:56 AM
hey rowbi,
not in the UK part of Europe, which is where I am...   we invented shoddy power :-)
  • 1
Regards
Rowbi
www.rowbinet.co.uk
#18 simbo
simbo
    Iknowathingortwo
  • PipPip
  • 114 posts
  • Registered Products:4
Posted 06 July 2013 - 01:27 AM
Hi casparello, Just out of interest did you by any chance get a thump through the cab or speaker when changing patches and a bit of interference.
simbo
#19 casparello
casparello
  • 43 posts
Posted 08 July 2013 - 01:00 AM
@ simbo
if you mean that I hear a small audible impact when changing patches -> yes
#20 jrose92081
jrose92081
  • 8 posts
  • Locationohio
Posted 17 July 2013 - 12:20 AM
I have the same issue it seems. I was playing straight into the amp (without HD500) and as I was turning up the volume I got a loss in power and a bad hum. I reset the amp and turned it back on, same issue but noticed a pop when i took it out of standby. Now the amp has very little power and is very dirty. Even voicing 1 is really dirty even with the drive at 1 in full power mode. Class A seems to have a louder hum. I had the tubes changed and the amp biased and same results. I even re-installed the firmware. I love this amp and the fact that it is a paper weight breaks my heart. I have it narrowed down to the processing board or the transformer. Any help would be much appreciated.
Also tagged with one or more of these keywords: dt 50, sound
