Hd150 Volume Issues
4 replies to this topic
#1 Natedog_37
Natedog_37
  • 47 posts
  • LocationTemperance
  • Registered Products:3
Posted 27 November 2013 - 10:16 AM
Ok I have all me settings setup to be about the same volume for the most part.
I have the volume setup to give me 100% so I have full control.
I move the master Volume to maybe 25% at shows we get it set to what is a good mix and go from there.
I turn the amp off between sets.
Come back for set 2 turn amp on, Master Volume is the same but the amp is 15% louders?
Other issue I am seeing is you move the volume a hair and it is loud as hell!!! more it a hair down and you can't hear it.
get to about 50% and the volume sounds the same
get to 100% and you can't tell it is much different than 50%
Why is this.
You would think the volume would have a equal sweep all the way up to 100% but that 100% is not the case.
I have been thinking of limiting the volume to say 30% and see what it does.
Anyone have this issue.
#2 strange_eye71
strange_eye71
  • 1 posts
  • Registered Products:4
Posted 28 November 2013 - 11:32 AM
yes I have experienced exactly the same issue with the master volume. My workaround was to set the channel volume a little lower to pull the master volume past the 3 o'clock ( where I have the most problems with the master volume knob) seems to work better. Good Luck.
#3 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2575 posts
  • LocationNew England
Posted 02 December 2013 - 06:30 AM
Don't set your channel volume to 100%.   The combined total volume is going to be the same - you will notice if you have your channel volume at 100% that when you turn the master volume past a certain point it does not get any louder - you've already reached the maximum amp output.
Instead set your patch channel volumes so that when you change patches the volume is where you want it to be, irrespective of where the master volume is set.
Then use master volume to adjust the sound based on the overall loudness you need for the place you are playing.
#4 Natedog_37
Natedog_37
  • 47 posts
Posted 04 December 2013 - 05:44 PM
Ah I will give that a try.  I was guessing the 100% was the issue.  But found it strange getting use to the settings.
#5 gabeberco
gabeberco
  • 1 posts
  • Registered Products:2
Posted 29 December 2017 - 08:08 PM
On my spider 450 watt amp 4 six seven years and I am still having issues with my master volume it's always been a problem but it's worth now
