Foot Switch Help
6 replies to this topic
#1 rayberne2
rayberne2
  • 1 posts
  • Registered Products:1
Posted 28 November 2013 - 07:24 PM
DOES ANYONE KNOW HOW TO USE A FOOTSWITCH  TO TURN THE AMP DRIVE UP OR  DOWN
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9212 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 28 November 2013 - 09:33 PM
You can't assign different parameters to footswitches like that, but you can assign almost any parameter to be controlled by one of the expression pedals.
#3 Dutchguitarist
Dutchguitarist
  • 74 posts
Posted 28 November 2013 - 11:54 PM
You cannot  use footswitched to do that but as far as I know you can control the amp's drive knob with the expression pedal. Simply use the controllers section of HD edit: select the amp, choose drive as parameter en set the desired min and max value.
  • 1
#4 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 29 November 2013 - 05:35 AM
If you only want to switch between two different Amp Drive settings you could use a footswitch to do this by creating two different presets, and set your device to FS Mode = ABCD.  Set up the presets so that the only difference is the Amp Drive setting; then use the footswitch to switch between the presets.
But if you want to control the Amp Drive setting within a range of Max/Min values then you must use an expression pedal as described above.
  • 1
.... John Lennon
#5 GTLazer
GTLazer
    Iknowathingortwo
  • PipPip
  • 215 posts
Posted 29 November 2013 - 05:53 AM
You can assign more than one parameter to the pedal as well, so you could have a sweep of the pedal that increases the drive but also reduces the channel volume to keep the overall level similar.
  • 1
You like my answer? Hit the up arrow. You no like my answer? Hit the down arrow. Sorted.
#6 alexisltd
alexisltd
  • 53 posts
Posted 29 November 2013 - 06:05 AM
to the OP check this http://www.youtube.c...h?v=U0sLDW1yvGU  and I think this can be achieved using an external footswitch like a boss fs-5L in PEDAL 2 jack
#7 bvaladez74
bvaladez74
    Iknowathingortwo
  • PipPip
  • 183 posts
  • LocationSan Jose, CA
Posted 29 November 2013 - 09:00 AM
Just assign an OD pedal to a switch.
