Spider 4 120 Has No Sound!
spider 4 spider iv no sound not working
15 replies to this topic
#1 razorstage
razorstage
  • 11 posts
  • Registered Products:2
Posted 29 November 2013 - 02:52 PM
My spider iv has no sound at all. When i plug the guitar in the tuner doesn.t register either. The closest service center is 2 hours away and all the posts that i've read always suggest going to adamn service center. Is there anything i can do to ge tthis working? Honestly, i'll never buy a line 6 prodict again. What a joke. No one services these things.
#2 rcriche
rcriche
  • 4 posts
Posted 30 November 2013 - 10:38 AM
i have the same problem with my new POD HD400
#3 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2494 posts
  • LocationNew England
  • Registered Products:3
Posted 02 December 2013 - 06:24 AM
Sorry you are (both) having problems.   On the Spider IV 120 - is this a new amp that you just got, or did this suddenly happen?  Are you able to change patches and adjust settings (as shown on the LCD panel)?   Did you try a different guitar and cable?  Factory reset?  Do you have a way to plug an MP3 player into the CD/MP3 input to see if the amp secion of the 120 is working?   Factory-authorized service centers are required for warranty service (no different than any other manufacturer).
Not familiar with the POD, but suggest you make sure you have the correct settings, outputs set correctly (through computer or cabled to amp), etc.
#4 razorstage
razorstage
  • 11 posts
Posted 03 December 2013 - 12:26 PM
#5 razorstage
razorstage
  • 11 posts
Posted 03 December 2013 - 12:28 PM
All of my lights are working as normal. I'll attempt to plug a mp3 player into the back when i get home. Can i buy a new motherboard myself and replace it if needed? I'm not driving 2 hours to get my amp looked at. This is definitely the last line 6 amp i ever purchase, my friend had the same problem. They aren't built well.
#6 razorstage
razorstage
  • 11 posts
Posted 03 December 2013 - 03:10 PM
When i plug my mp3 player in the back i get no sound either....all of my channels and electronics are working as normal.  Footswitch is good.  Reset the unit a dozen times.  what do you think this could be?
#7 razorstage
razorstage
  • 11 posts
Posted 03 December 2013 - 03:13 PM
my unit is out of warranty....I also used the amp about 5 times in a 2 year time period where it was stored in my home in a climate controlled room.  I need to fix this myself.  Where can I purchase parts?
#8 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2494 posts
Posted 03 December 2013 - 05:36 PM
Have you tried plugging in headphones (or using line out to your computer or an amp)?  Parts can be ordered direct from Line 6, but how do you know what to replace unless you can troubleshoot it.?
#9 razorstage
razorstage
  • 11 posts
Posted 03 December 2013 - 06:35 PM
When the guitar is plugged in and i activate the tuner there is no signal. Also, no mastery hours loud i turn the mastery volume up the speakers don't hiss, nothing. I tried disconnecting the speakers and reconnecting. Nothing there.
#10 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2494 posts
Posted 04 December 2013 - 05:36 AM
Before you indicated 'all the channels and electronics are working fine', now you say the tuner does not work.  Which FBV foot switch are you using?  Does it work changing the patch channels but the tuner does not work on it?  Unplug the FBV, does the tuner work on the amp itself (by holding in the button to activate)?
The fact that the MP3 input does not produce any sound would indicate the amp section is not working, (headphones should be used to verify that it is not just the main power-speaker output).  If there is also problems with the preamp section (tuner, FX knobs don't work), then you've got more than one problem.  Only a qualified tech person is going to be able to troubleshoot it.  You could certainly open up the chassis and look for possible burned-out components or loose wires.
#11 razorstage
razorstage
  • 11 posts
Posted 04 December 2013 - 05:38 AM
my very first post I stated that the tuner does not pick up a signal when I am plugged in. the tuner activates but it doesn't pick up me hitting the strings.
#12 razorstage
razorstage
  • 11 posts
Posted 30 December 2013 - 04:48 PM
UPDATE:  I replaced the power amp board and the input jack.  MY AMP STILL DOES NOT WORK.  It turns on but has no sound coming through the speakers, no hiss...nothing.  The tuner still shows no signal when i activate it.  Beyond frustrating.
#13 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2494 posts
Posted 31 December 2013 - 05:15 AM
Sorry it didn't work, but I did caution you about 'how do you know what is not working?'
#14 razorstage
razorstage
  • 11 posts
Posted 31 December 2013 - 05:24 AM
I'm dropping the amp off at a service center today. As soon as this piece of garbage is fixed I'm selling it! to be completely honest with you, it doesn't even model the amps that it is supposed to do very well. when you change channels the volumes fluctuate so much that it takes hours just to program this thing if you want to use it in a live setting. I will be purchasing a Vox Valvetronix as soon as this lump of wood is sold.
#15 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2494 posts
Posted 02 January 2014 - 05:10 AM
Sorry you had problems with it. Of course, like any piece of modern electronics, you need to learn how to use the features (in the case of the volume changes, you have to SAVE into your user patch locations at the channel volumes you want - master volume is not saved).  It's a pretty simple procedure once you learn the steps.  As for the amp modeling, the latest generation of Line 6 modeling is right up there with other manufacturer's modeling offerings.
#16 razorstage
razorstage
  • 11 posts
Posted 02 January 2014 - 05:20 AM
I know how to use modern technology, thanks. The amp sucks. I just bought a brand spanking new Orange c60 last night. It blows the line 6 the water in every imaginable way. I made a mistake buying the line 6.
I dropped the lollipop 6 off at the service center Tuesday..once it's fixed I'll sell it to someone else who thinks he's getting a great amp...
Also tagged with one or more of these keywords: spider 4, spider iv, no sound, not working
