Pop Hd300 Does Not Play In Garageband
record usb garageband midi connect to mac pod hd300
Best Answer bjnette , 15 May 2013 - 03:47 AM
Have you recorded other instruments in GB? As it might be in arming it.
Check buffer size as well as too little and it won't want to work. Check other setting as well.
Hope your up and running
Go to the full post
1 reply to this topic
#1 MarkPod300
MarkPod300
  • 26 posts
  • Registered Products:6
Posted 12 May 2013 - 10:53 AM
Hello Everybody,
New Pod hd300. Works perfectly with headphone connected directly into the pod. Installed all drivers in iMac, latest udpates done. Monkey is updated. Pod300 Edit installed and recognizes the pod. When I change a knob on the pod it changes at the same time on the iMac in the pod hd300 edit software. So I guess connection is ok. I also see the pod as midi device in the midi manager So far so good. But in Garageband nothing happens. Does not seem to recognize the pod. Nevertheless in preferences the I did select the pod and when I go to the amp I also see the pod as input source.
What am I doing wrong. Any suggestion.
Thanks in advance
Markus
#2 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1205 posts
  • Registered Products:2
Posted 15 May 2013 - 03:47 AM   Best Answer
Also tagged with one or more of these keywords: record, usb, garageband, midi, connect to mac, pod hd300
