stormwind Posted May 13, 2013 Share Posted May 13, 2013 I`ve tried to upgrade DT25 to firmware 2.0 through MIDI. Line 6 Monkey couldn`t find my DT25 when I tried to do this with an USB-MIDI interface, so i tried with internal (onboard) MIDI port in my PC. Monkey found it instantly so i started to upgrade from file. (previously i used this port to work on Zoom g7.1 ut and never had problems with it). Update process started. After a while a well-known (800000a propably with connection) error occurred and now my amp is just a random-light-lit piece of junk. Doesn`t react on any of the switches. Tried to reflash the thing but now Monkey doesn`t detect the amp. I looked through the forum, found out that there is another way using MIDI Ox to transfer firmware file. Tried that, didn`t work (program sends somewehere file but nothing happens). Tried to run amp in "Service mode", tried "hard reset". Didn`t work. Still can`t detect amp in monkey :(. Any solutions? Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted May 13, 2013 Share Posted May 13, 2013 don't know much about that but line6 gear doesn't like to many usb-midi devices except for m-audio midisport uno. can't you upgrade using usb? Quote Link to comment Share on other sites More sharing options...
stormwind Posted May 14, 2013 Author Share Posted May 14, 2013 No, nothing helped. Tried even with L6 link (found somewhere that it should work?) - that didn`t help either. I contacted technical support and now my DT25 is on it`s way for repairs :/ Thankfully my POD HD400 upgraded without problems, but that goes through USB and it`s a different story... Quote Link to comment Share on other sites More sharing options...
