More Robust Ethernet Cable And Rj45 Plugs
19 replies to this topic
#1 BigRedX
BigRedX
  • 8 posts
  • Registered Products:1
Posted 02 December 2013 - 02:03 PM
I posted this in the Pod section, but thought it might be a bit more relevant here. Please forgive my multiple posts...
I find myself getting through far too many ethernet cables for attaching my FBV Shortboard to my Bass Pod XT Pro.
Generally what happens is that the plastic clip that locks the RJ45 connector into the socket on the Shortboard snaps off which means that the plug is no longer sufficiently secure in the socket for the pedal to work reliably. However I have had other cables fail with no visible signs of damage - most likely due to a conductor breaking somewhere along the length of the lead.
My band's gigging and rehearsing schedule is such that the gear is set up and broken down at least 10 times a week and with this kind of use standard ethernet cable and RJ45 connectors simply aren't robust enough. Currently I'm lucky if a new cable lasts me more than a couple of months. Normally I carry a spare lead, but after a recent gig where both my main ethernet cable and the spare both broke while setting up, I'm looking for something a bit more durable.
So, what do the pros use? Is there a recommended supplier of heavier-duty cable and less easily damaged RJ45 plugs? Do they have their Line6 equipment modified to use EtherCON connectors? In which case can you recommend me someone who can do this for me in the UK?
All useable ideas and suggestions gratefully received.
spiderqueen_vinyl_zps3c18da7d.jpgspiderqueen_itunes_zps58563e5a.jpgspiderqueen_amazon_zps878dbbd9.jpg
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17789 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 02 December 2013 - 02:13 PM
I'd bet that this guy: http://line6.com/sup...cool-vdi-cable/
could probably make you something pretty durable.
#3 BigRedX
BigRedX
  • 8 posts
Posted 02 December 2013 - 02:33 PM
Thanks. I've posed the question in the thread. However the leads he's currently offering use EtherCON plugs which are no good for the Pod or Shortboard. Hopefully he can recommend and supply a plug that is more durable than the standard RJ45, but still fits in the normal socket.
Fingers crossed...
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17789 posts
Posted 02 December 2013 - 02:38 PM
yeah, but if you're custom making them it's super simple to add whatever end...
personally i think it'd be more cost effective to just carry a spare...
although i do think that the upgraded cables are nice for the VDI... just don't think i'd go too far out of my way for the FBV cable...
of course if it's worth it to you.... then by all means! :)
#5 BigRedX
BigRedX
  • 8 posts
Posted 02 December 2013 - 02:55 PM
I do carry a spare. It's just that at a recent gig I managed to break both cables and despite taping one of them to the Shortboard with Gaffer tape it still managed to work loose during the gig causing the Bass Pod to crash and reboot mid-song which was not a happy moment.
The high-energy rock and stage performance of my band means that I don't have time to lollipop about between songs trying to fix technical problems. I want a robust no-nonesense solution that I can rely on not to let me down. Currently the connection between the Pod and the Shortboard is weakest link in my rig by a long margin and I want to stop it being so.
Also I've probably spent more on replacement ethernet cables in the last 18 months then a couple of well made suitably robust ones would have cost. In the same time period none of the other leads in my bass rig or the Theremin set up have failed.
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17789 posts
Posted 02 December 2013 - 03:31 PM
sounds like you're on the right track...
#7 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15871 posts
  • LocationOntario, Canada
  • Registered Products:15
Posted 02 December 2013 - 03:35 PM
@ BigRedX: what's with the embedded links in your signature? It's not really OK to try to market/sell stuff here with every post you make - can you please remove it?
.... John Lennon
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17789 posts
Posted 02 December 2013 - 04:46 PM
I think they are of his band, and self promotion is probably ok... just looks commercial because of the branded links to buy their music...
#9 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15871 posts
Posted 02 December 2013 - 06:11 PM
OK - looks commercial to me but perhaps not.......
.... John Lennon
#10 BigRedX
BigRedX
  • 8 posts
Posted 03 December 2013 - 04:25 AM
silverhead, sorry if the links are causing you a problem. Before adding them to my signature I did look at the "Welcome to the Line 6 forums" post and waded through the impenetrable legalese of the Forum Terms & Conditions but I couldn't see anything that prohibited them.
If they are against forum policy and an official forum moderator or admin asks me to remove them I'll be happy to oblige.
They are simply links to my bands music that has been produced using various pieces of Line 6 equipment that I've been happy to use for the past 10 or so years...
And ultimately it is the music that is produced that as musicians we should be celebrating is it not?
  • 1
#11 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2539 posts
  • LocationNew England
  • Registered Products:3
Posted 03 December 2013 - 05:33 AM
I agree regarding the cables and connectors.  Since I first got my Spider IV 75 I have noted that the amp jack does not hold the cable connector very securely.
#12 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
Posted 03 December 2013 - 07:27 AM
I have had the best service and highly recommend these guys for your cable needs.  They make top quality gear at reasonable prices and build to order.
http://best-tronics....t/tactical.aspx
PS. I have absolutely no relations or business interest with them, they just do the job.
#13 BigRedX
BigRedX
  • 8 posts
Posted 03 December 2013 - 08:00 AM
Thanks!
I assume you are recommending this cable option, or is there a better one you think I should be looking at?
Also I'm in the UK. I've emailed Best-Tronic to see if they do international shipping but unfortunately IME companies that don't mention it generally don't...
#14 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
Posted 03 December 2013 - 08:25 AM
I haven't ordered these from them but I have plenty of other cables that were all very high quality at reasonable prices.  While these are for Line 6 products, I can't tell if the connectors are higher strength than regular.  I suggest you ask them direct for recommendations once they reply to you.  They build for many major touring acts and industrial applications too so I am sure they have a solution that can work for you... let us know how it works out!
#15 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2539 posts
Posted 04 December 2013 - 05:41 AM
Yes, update us on better cables if you find them!  I'd buy a spare, just in case.   Unfortunately, the connectors on the amp and FBV still are flimsy.
#16 frac82
frac82
    Iknowathingortwo
  • PipPip
  • 121 posts
  • Registered Products:2
Posted 24 December 2013 - 07:46 AM
which type of ethernet cable (cat. 3, 4, 5 or 6? crossed?) should i look for to get a backup/spare wire for my MKI FBV? thax, merry xmas
#17 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17789 posts
Posted 24 December 2013 - 09:21 AM
standard cat5 or cat 6... DO NOT USE A CROSSOVER cable.
#18 frac82
frac82
    Iknowathingortwo
  • PipPip
  • 121 posts
Posted 24 December 2013 - 10:30 AM
thanx! and merry xmas again. p.s.: http://line6.com/sup...d-ii-contr-r506
#19 kutsab
kutsab
  • 2 posts
  • LocationNorCal
Posted 17 May 2014 - 07:03 AM
I know I'm necrobumping this, but I ordered a 3ft Durapatch from Rapco (should have been a 6) to use at home with my fbv right in front of my amp and definitely think a longer one would be great for stage...
I'm also looking to mod my fbv and my amp with som ethercon jacks. I didn't have any luck with the forums on finding anyone that's attempted this, but I figure since I'll need a new fbv (2 switches don't work) I might as well Frankenstein it.
http://www.amazon.co...=Durapatch rj45
SpiderValve Mki - FBV Shortboard
Marshall JCM 2000 DSL 100 - Pod XT Live
'71 Gibson - '54 LP Custom reissue
'09 Cordoba Jet 15
'06 Axxion
'05 30th Anniversary Eclipse
'02 Jackson Dinky
'00 Jackson RR3
'?? Charvel SSH
#20 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2539 posts
Posted 20 May 2014 - 04:31 AM
The link is for a 30 cable, that would be about right for typical stage set up.  Let us know how your jack replacement project goes!
