Dt25 V2.0 Update
dt25 monkey update v2.0
7 replies to this topic
#1 Ngoins01
Ngoins01
  • 2 posts
  • Registered Products:4
Posted 02 December 2013 - 02:43 PM
I am attempting to update my dt25 to version 2.0. I have it plugged into a mac mini running mavericks via a mil usb-midi interface. Everything seems to be installed correctly, but when I launch Monkey to update the software, the only device that appears in my drop down menu is "PODxt". Even when I click the "Connect to MIDI Device",  "PODxt" is the only thing that appears. It would be great to get my amp updated. If anyone could help, it would be appreciated.
#2 Metalchef
Metalchef
    Iknowathingortwo
  • PipPip
  • 197 posts
  • Registered Products:2
Posted 03 December 2013 - 04:44 AM
It's been awhile but I believe that mine did the same thing and I updated from midi I believe. I remember it kept declining the update then I went via the back door and it worked. Also make sure that your amp is registered with line 6 I had to do that prior to update as well.
Yes I hear the cries of the carrots.... For it is harvest day and to them it is the Holocaust..... So I say let the rabbits wear glasses....
#3 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
Posted 03 December 2013 - 07:58 AM
Did you switch the in/out cables? Just a thought. Sometimes they end up backwards.
#4 Metalchef
Metalchef
    Iknowathingortwo
  • PipPip
  • 197 posts
Posted 03 December 2013 - 12:27 PM
I believe mine did the same thing and you can update from file and then it pops up the warning that monkey doesn't recognize or that midi doesn't recognize the amp but there is an option to upload anyways on the screen that tells you to make sure your cables are properly connected and such. Just let it rip.
  • 1
#5 joakey
joakey
  • 4 posts
  • Registered Products:1
Posted 10 December 2013 - 01:20 AM
I tried to update my DT25 112 to firmware version 2.00 last night and had problems.  I thought I'd post here in case anyone else has a similar experience.
I bought a good quality USB - MIDI cable for this purpose, having read reviews of cheap cables on Amazon that often said they caused problems.  I have the Monkey (and HD500X) software installed on my Windows 8.1 laptop, and it seemed to install the drivers for the MIDI cable without any problems as soon as I plugged it into the USB port.  However, I couldn't get the Monkey to recognise my amp until I had rebooted the laptop, so that was the first gotcha.
On the subject of the cables, I did put the MIDI IN cable into the Output socket of the DT25, and MIDI OUT to the Input socket.  No issues with that.
Having rebooted, the Monkey recognised my amp, told me that it was running firmware v. 1.00 and that 2.00 was available. so I told it to upgrade.  It seemed to go through the whole process alright (downloaded the new firmware, installed on the amp, reinitialised the amp) but then told me it had failed due to an unknown error (always helpful, thanks developers!).  However, when I rebooted everything and reconnected, it reported that the amp was on version 2.00 so I thought it was ok.
Then I plugged in my guitar...
Nothing.  Not a sausage.  Just a speaker crackle when I turned the amp on.  Switches unresponsive (e.g. amp selection), no sound from the guitar either directly or via my HD500X.  I tried rebooting everything, I tried doing the factory reset on the amp, to no avail.  Then I tried to reapply the upgrade and to roll back to version 1.00 in the monkey software, but that didn't work.
Eventually I hauled my amp upstairs and plugged it into my desktop, which is on Windows 7.  Happily, that worked fine and I was able to roll back to version 1.00, and my amp works again.  Phew!
I don't even know why I wanted to upgrade, except that the upgrade is recommended by Line 6.  If you have a pod (which I do), it doesn't give you any new sounds - it just means that you can also access the 30 amps without the pod.  Great if you don't have a pod, no doubt.  However, the other issue is that there is no software for me to actually make those settings on my amp - they only have software available for iOS, and we aren't all Apple fanboys, Line 6!
So I'm going to stick with version 1.00 of the firmware.  I decided to post this in case anyone else encounters the same problems, or to forewarn anyone wanting to upgrade from a Windows 8 / 8.1 PC that they may run into problems.  For me, there are two essential lessons learned here:
1) Be careful about upgrading from a Windows 8 / 8.1 PC unless you're sure that your MIDI drivers are 100% compatible
2) Don't bother with the upgrade unless you have an iDevice or you have MIDI control software on your PC and are familiar with its use.
Finally, I love the amp but I have to say that this experience was not good, and wasted a lot of potential guitar time! :(
#6 innovine
innovine
    Iknowathingortwo
  • PipPip
  • 322 posts
Posted 10 December 2013 - 05:25 AM
You can supposedly do a factory reset by holding the topology and channel switches towards each other when powering on.
I say supposedly, because when I did it, the amp seemed to revert back to the original behaviour, but monkey kept insisting that the amp was at version 2.0.
Monkey did allow me to reinstall v2.0 anyway, but I dislike these little glitches around such a delicate process.
  • 1
#7 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
Posted 10 December 2013 - 06:54 AM
There is a very good DT edit program stickied at the top of this forum. Designed for windows and built by a member of the forum. I use it and it works great. Give that a try. Sorry to hear you had so many issues.
#8 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 10 December 2013 - 07:28 AM
Doing this reset process only resets the presets to factory as I have done this several times after a successful install of v2.0 on a DT50 Head. Also I've been using DT Edit software to access the new options with no real problems on a 5 year old Vaio Laptop with Win 7. Also I agree that if you're having these issues it's dissappointing and I would feel the same way as Joakey and anyone else.
  • 1
Also tagged with one or more of these keywords: dt25, monkey, update, v2.0
