Pod Hd Pro+power Amp+cab Clipping/low End Problem
pod hd pro power amp tone metal 8 string
6 replies to this topic
#1 GageGoss
GageGoss
  • 1 posts
Posted 03 December 2013 - 05:33 PM
I have a Pod HD Pro set up with my Carvin DCM 200L going into an Orange 4x12 cab and I play pretty heavy metal/high gain type stuff. I'm having an issue with the low end sounding overwhelming or even slightly clipping when I hold a palm muted note. I play an Ibanez RGA8 8 string so naturally there will be a lot of bottom end anyway but it sounds like the tone begins to swell and just overwhelm everything when I hold an open palm mute. I was wondering if its my signal chain or the power amp or the cab or even that's just how the guitar will sound because of the low tuning.
Any input will help!
#2 AndyParedes
AndyParedes
    Line 6 U.S. Product Specialist
  • Product Specialist
  • PipPipPipPipPip
  • 4485 posts
  • LocationCalabasas, CA - USA
  • Registered Products:8
Posted 04 December 2013 - 09:51 PM
Try backing off the low end and/or gain on your tone and see if that changes anything.  You can also try a different cab to see if that changes the situation.  You already have a ton of low end, if you are running a scooped-mid tone that could be exacerbating the situation.
Regards,
Andy
@line6aparedes
http://line6.com/tone-templates/
#3 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1094 posts
  • Registered Products:3
Posted 05 December 2013 - 06:20 AM
Hey, another 8-string player here. My guess is that you simply have too much bass in your tone. I'm assuming you're already running some sort of boost drive in front of the pre-amp, so a place to start might be there by backing off some low end and increasing the middle on your boost. Also, if you have any compressors in your chain, especially post-amp or right at the front you may want to check your settings, as this can cause the issue as well. May want to examine pick-up height, as well. FWIW, I've gone to a pretty basic Gate->Boost->Gate->Amp chain and its made my tone way, way clearer. I'm using the Mesa model with the gain at about half way with a boost in front with drive at 3, lows at 25, mids at 100, highs at 75, and the output at around 75.....sounds a little dry by itself but the mutes hold long and tight and when the kick and the bass get in there, its fvcking massive.
#4 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1226 posts
  • LocationVirginia
Posted 05 December 2013 - 07:04 AM
Are you using Cab modeling in the PODHD ?  Are you using the Pre or Full amp modeling ?  Are you running Studio Direct into the Effects return of your amp ?  Need a little more info before making a suggestion.
#5 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1094 posts
Posted 05 December 2013 - 09:11 AM
also, orange cabs are super boomy in my experience. I have yet to see a band a live with them where I thought "Damn, that tone sounds awesome!" Usually they sound muddy, sludgy, undefined, and lacking in upper mids (to my ears)
#6 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
Posted 05 December 2013 - 10:10 AM
For strictly booming on the low end, I have had the best results by going into the CAB DEP and setting the LOW CUT to 110-140 and adjusting RES LEVEL and THUMP to taste.  You don't have to tweak the rest of your signal chain to fix this... give it a try...
#7 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1226 posts
  • LocationVirginia
Posted 05 December 2013 - 02:52 PM
That's exactly what I do too but I didn't know how he had his PODHD setup.  I set low cut to 140 and reduce Resonance to 40% when using ANGEL Pre through 4x12 XXL cab and 4038 ribbon mic.  Then I have it going studio direct into the effect return of a Marshall amp into a 4x12 cab.
  • 1
Also tagged with one or more of these keywords: pod hd pro, power amp, tone, metal, 8 string
