Spydervalve Mki 1/12 Rattymid To High Gain Tones
grainy high gain tones spyder valve mki
2 replies to this topic
#1 wehrwulfe
wehrwulfe
  • 1 posts
  • Registered Products:1
Posted 13 May 2013 - 01:41 PM
i was given a 2007 model sv mk 1 and while the clean sounds are very good ,turning up the drive encoder on any model results in a real nasty "barkY"(i guess thats a word) .tone.. very grainy...the tone controls seem to have minimal effect even after I spin the knobs to start at "0".the tubes are orginal .and one of the power tubes has a bright blue ring around the area where the plate(?) ends . any ideas??/id like to keep it.
#2 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 14 May 2013 - 04:40 AM
i've read good and bad. i would change the tube. get the amp biased. http://www.marshallf...acuum-tube.html
I'M SO HAPPY!
#3 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5373 posts
  • Registered Products:6
Posted 14 May 2013 - 07:02 PM
+1...Sounds like one of your power tubes is going...That can put the amp way out of bias. What that means is the top (+) of the sine waves will notch as they cross to the bottom (-)...The result is generally exactly as you describe...the tone gets unusually rough really quickly. Good idea to change all the tubes on this one I think...and adjust the bias proper for the tubes you get....
  • 1
