Hd500 Won't Initialize When Powered Up
hd500 hd edit
6 replies to this topic
#1 pklhead2
pklhead2
  • 3 posts
  • Registered Products:2
Posted 08 December 2013 - 09:28 PM
I was trying to transfer some customtones from the HD Edit app into my Pod HD500 tonight and received a Code 800000a error saying something timed out - restart your hardware and the app.
I closed the app and powered off the HD500. When I plugged it back in, the display screens brings up a Line 6 logo, then fades out and brings up the logo again, fades out and repeats again, and again. Appears to be in some kind of loop when initializing.
Any way to get past this error?
#2 racah15
racah15
  • 7 posts
Posted 09 December 2013 - 01:22 AM
Nope, your HD is bricked as far as I know. Did you update the firmware and accidentally interfere somehow? You will most likely have to get it checked out by Line 6.
#3 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 09 December 2013 - 02:00 AM
Perform a Global Settings reset.
Instructions available here.
Also make sure to re-calibrate the onboard expression pedal of the HD500 after performing the Global Settings reset.
How to calibrate the POD HD500 Expression Pedal.
#4 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
Posted 09 December 2013 - 09:12 AM
Sometimes a corrupt patch can do this. Follow instructions above.
  • 1
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 09 December 2013 - 09:18 AM
Try holding down the right nav key while powering up. If it doesn't start normally, you may see a test screen display. Select REFLASH (or FLASH/MEMORY?). Then run Line 6 Monkey and reinstall the firmware. When prompted, choose to replace existing presets.
.... John Lennon
#6 pklhead2
pklhead2
  • 3 posts
Posted 10 December 2013 - 07:35 PM
Thanks friends. I restarted as directed above and the HD500 came up with "UPDATE FLASH" so I opened Line Monkey and reinstalled the firmware. First time after restarting it still was looping the Line 6 logo screen, so I reinstalled firmware again. Still looping after install. So Third time I restarted with the left arrow key and the regular set list screens appeared. Hopefully I've cleared whatever goblins were in the machine.
Thanks for the helpful advice.
#7 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
Posted 11 December 2013 - 04:03 AM
Glad to hear you solved the problem.
Don't forget to recalibrate the POD HD500 Expression Pedal.
John
