Plugging Direct To Pa And Monitoring Via Amp
monitoring direct pa
Best Answer joel_brown , 10 December 2013 - 12:55 PM
I just looked it up and it said the Spider 3 has a CD/MP3 input.  Connect your PODHD there and that's about the best your going to get out of that amp.
Go to the full post
12 replies to this topic
#1 scias23
scias23
    Iknowathingortwo
  • PipPip
  • 102 posts
  • LocationManila, Philippines
  • Registered Products:2
Posted 09 December 2013 - 01:22 AM
I want to connect direct to pa via the xlr outputs, and at the same time, output my signal to my amplifier.
I have a spider 3 amp and the sound is horrible when plugging my pod hd500x to the amp. It sounds like the mids are more emphasized and I can't get the bass sounds tinny.
I've tried plugging the unbalanced out to a di box and plugging a 1/4 inch jack from the link output of the di box to the amplifier, and plugging the xlr output to the pa, but the monitor sound through my amp still sounds awful.
Any suggestions?
#2 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationVirginia
  • Registered Products:3
Posted 09 December 2013 - 05:09 AM
What is your output setting ?  Is it Studio Direct ?
#3 Leftzilla
Leftzilla
    Gear Head
  • PipPipPip
  • 553 posts
  • LocationBurlington, VT
  • Registered Products:10
Posted 09 December 2013 - 07:23 AM
If you want to send direct to the pa and monitor onstage then you will need to use a full range amp such as a keyboard amp.  The eq outputs for a PA should be studio direct which will not sound good when sent to a guitar amp.  If you set up for your amp to sound good then you should just mike it.
#4 scias23
scias23
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 09 December 2013 - 04:47 PM
Yes, studio direct.
#5 scias23
scias23
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 09 December 2013 - 04:49 PM
Is there any other way other than using a full range amp?
#6 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationVirginia
Posted 09 December 2013 - 05:18 PM
If your guitar amp has an Effects Return, you can plug the PODHD into that.  That bypasses the preamp of your guitar amp and just uses the power amp section.  Basically giving you a full range amp.  I do this all the time.
#7 scias23
scias23
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 09 December 2013 - 06:32 PM
It seems that the Spider III amp doesn't have an effects return.
#8 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationVirginia
Posted 09 December 2013 - 08:18 PM
Not good.  Yep it'll sound bad.  You may be able to help it by turning down your pre-amp or channel volume on the amp but it won't sound like what you get through the PA.
#9 Leftzilla
Leftzilla
    Gear Head
  • PipPipPip
  • 553 posts
Posted 10 December 2013 - 04:43 AM
I am not sure that going into the effect return would give you the results you want even if the spider had one.  Joel Brown may be absolutely right, and it has been a long time since I have used a guitar amp, but I still think the EQ bias of the guitar amp speaker itself wont match the PA.  But like I said I could be wrong on this.
I personally use a 50 watt behringer kybd amp (180 bucks) to monitor my sound on stage or fold back through the bands monitor system.  I run the sound for my band so I can give myself custom monitor mix if I need to.  I am not sure what options you have in that department.
Have you ever gotten a good sound running the PODHD into the Spider?  Another option would be running the PODHD into the spider using the Amplifier output mode (I apologise I don't know the mode name for going into a guitar amp) and see if you get a sound that you like from the Spider and then mike it.  But all of the presets that sound good in the spider will probably not sound so hot when you record or send direct to the PA.
Hope this helps.
#10 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationVirginia
Posted 10 December 2013 - 05:31 AM
I run my PODHD through the Effects return of a pair or Marshall JCM900s when I play live.  Sure it'll color the tone some, but it'll be close enough for a monitor and won't sound like crap.
#11 stumblinman
stumblinman
    Gear Head
  • PipPipPip
  • 882 posts
  • LocationPacific Northwest
Posted 10 December 2013 - 10:12 AM
If there is an MP3 line in you could use that to bypass all the spider modeling. I know the 4 has a bypass if you hold the nav button a certain direction while turning it on, not sure on the 3.
#12 joel_brown
joel_brown
    Power User
  • PipPipPipPip
  • 1236 posts
  • LocationVirginia
Posted 10 December 2013 - 12:55 PM   Best Answer
#13 scias23
scias23
    Iknowathingortwo
  • PipPip
  • 102 posts
Posted 10 December 2013 - 06:38 PM
I'm gonna try hooking the device to the mp3 input.
The sound is horrible even after setting the amp model to clean and setting the eq knobs to 12 o'clock. The mid is overemphasized and bass is dull.
Also tagged with one or more of these keywords: monitoring, direct, pa
