Input Z
2 replies to this topic
#1 zipline7020
zipline7020
  • 3 posts
Posted 09 December 2013 - 09:46 PM
So I just learned about input Z
I was wondering if someone could help explain the full effects of it ?
and also if my patch consists of
schecter hotrod w/ dimarzio breeds ---> noise gate --->tube compressor---->tube screamer-----> mesa-----> computer,
which setting do I need to put it on?
22k
32k
70k
90k
136k
230k
1m
3.5m
#2 GTLazer
GTLazer
    Iknowathingortwo
  • PipPip
  • 215 posts
  • Registered Products:1
Posted 10 December 2013 - 02:09 AM
I just leave mine on Auto all the time.
You like my answer? Hit the up arrow. You no like my answer? Hit the down arrow. Sorted.
#3 RIblues
RIblues
    Iknowathingortwo
  • PipPip
  • 291 posts
  • Registered Products:2
Posted 10 December 2013 - 03:13 AM
From Line6:
New Variable Input Impedance gives guitarists eight selectable options to enhance their tone. When set to "auto," the impedance matches that of the first amp or effect in the chain, creating the same response as plugging into the modeled original. Seven discrete resistor values (22k, 32k, 70k, 90k, 230k, 1M, 3.5M) can also be selected to further sculpt the sound, actually changing the analog circuitry. Impedance settings are saved with each preset.
These settings are very valuable in tweaking your tone, with my Strat, I lower the value to around 32K on some patches and achieve the tone that I was set out to create. If you find that a particular patch that you are working on is a little too bright or thin and adjusting the amp or other Eq settings is not working for you, experiment with these settings and I think that you will be happy with what you find.
They react quite differently depending on the pickups that you are using and the amp and effects models that are in your patch.
