Problems With The Volume And Wah Fbv Express Mkii
fbv mki / mkii controllers
5 replies to this topic
#1 agauna69
agauna69
  • 2 posts
  • Registered Products:1
Posted 10 December 2013 - 05:36 AM
Hello, I need help in MKII express connected to my POD 2.0, the issue is that the volume did not work, and when I press to use WAH can not give expression, the volume pedal not raise or lower the sound.
Please help with this issue and to generate calibration as given by pressing D and connecting USB, but to also not work.
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8486 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 10 December 2013 - 06:26 AM
On the jack for the foot controller on your POD, does it say "FBV"? If your 2.0 is an older version, it may not be compatible with the MKII Express.
#3 agauna69
agauna69
  • 2 posts
Posted 10 December 2013 - 10:10 AM
Not the new version if it actually worked to pricipio hassle then apparently desconfiguro works everything but the volume and expression of WAH.
#4 ZandraXara
ZandraXara
  • 2 posts
Posted 27 November 2014 - 10:21 PM
check the FBV port on the pedal... or on the pod.. sounds like you might have some bent pins.
ZANDRA XarA
#5 ZandraXara
ZandraXara
  • 2 posts
Posted 27 November 2014 - 10:33 PM
Assuming you have a Spider IV.  You can control many parameters, such as pitch bend, by programming the amp settings in a patch.  Suggest you read the amp manual
ZANDRA XarA
#6 fflbrgst
fflbrgst
    Power User
  • PipPipPipPip
  • 2470 posts
  • LocationNew England
  • Registered Products:3
Posted 01 December 2014 - 05:31 AM
Hopefully the OP got it figured out - the post you replied to is almost a year old!
