500x Expression Pedal Not Responding
hd 500x troubleshooting
4 replies to this topic
#1 tgrau121
tgrau121
  • 1 posts
Posted 11 December 2013 - 02:45 AM
Hello. For some reason my expression pedal does not seem responsive when i turn on effects through it. Turning the effect on and off has not been troublesome, but none of the effects change, all sounds remain static, at the fully down position. Even the preset models that use the pedal as a volume pedal are non responsive. i have yet to move it and long distance, it hasn't been dropped, so i doubt its a hardware problem. Thanks for the help, Tom
#2 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 11 December 2013 - 05:36 AM
You must calibrate the POD HD500 Expression Pedal.
#3 Zohaib
Zohaib
  • 1 posts
  • Registered Products:2
Posted 21 April 2016 - 07:53 AM
I calibrated my expression pedal.. But it isnt responding to anything. It isnt even working as a simple volume controller on any of the tones. It is switching on exp 1 and exp 2 and it is showing proper values (0-255) in calibration mode but it still isnt working....why?
#4 DunedinDragon
DunedinDragon
    Power User
  • PipPipPipPip
  • 1268 posts
  • LocationDunedin, FL
  • Registered Products:3
Posted 21 April 2016 - 08:22 AM
Do you have the volume pedal in your signal chain and is it enabled?
#5 pianoguyy
pianoguyy
    Power User
  • PipPipPipPip
  • 1933 posts
Posted 21 April 2016 - 12:21 PM
Don't you just love the repeat questions. It's almost as if L6 doesn't offer a forum search feature.
On the 500, it is an EXP pedal. It is not exclusively a volume pedal or wah pedal.
The EXP pedal must be assigned to something.
If you want to use it as a volume pedal, you must put a volume pedal in the chain, and then you must assign the EXP pedal to be the controller.
It can control anything you want, but it must be assigned first.
And it sure would be nice if I could use 500edit on my Android Phone or Android Tablet to manage my Pod when not at home.
Even if it needs to be a '500 Lite' version that only allows for the import and export of patches, and not a full-fledged working program.
Something needs done.
