Sync100 Posted December 11, 2013 Share Posted December 11, 2013 Hi everyone,When using hd edit, sometimes when moving a knob within hd edit the program freezes.If I then turn a knob on the pod the program unfreezes until I move a knob on the program, then it freezes again.I have reinstalled the drivers and program and changed usb slot.I've launched a support ticket but wondered if anyone here has had the same thing happen?Specs below,Thanks for any help, Mike Pod HD desktop (bean) i7 3.3ghz, 8mb DDR3, Emu 0404, Win 7 x 64 Thanks :) Quote Link to comment Share on other sites More sharing options...
guitarno Posted December 11, 2013 Share Posted December 11, 2013 That is strange behavior. I will say that in most peoples experience, including mine, you should either make all your changes on HD edit, or on the hardware, but not both at the same time. If you make changes on a patch in HD edit and then change some controls, or use the expression pedal on the HD500, the 2 get "out of sync" and you can get some pretty strange results. You should in general do all of your changes in HD edit, then save the patch before changing any controls on the hardware. You should actually avoid touching anything on the hardware until you save the patch in HD. I'm not sure I ever had HD Edit freeze up as you have. I'm not sure if that is a separate issue or not, but try editing without touching the hardware at all and see if that helps. Quote Link to comment Share on other sites More sharing options...
