Troubles With Recording Via Pod Xt Live
pod
7 replies to this topic
#1 kr0lik_roger
kr0lik_roger
  • 6 posts
  • Registered Products:1
Posted 12 December 2013 - 02:23 AM
Hello,
I have a guitar ESP eclipse II with active pickups and I use Pod XT Live as audio interface. The signal handle on the outlet is set to maximum but not clipped. During the recording a guitar rhythm doesn't cause any problems, but when I'm recording solo, outlet sound comes out very quietly, approximately -15 db. How to amplify the level of a sound? Previously I had Tone Port and used Pod Farm, which has a button "+18 db", I pressed the button and outlet sound became amplified (louder). Then I was recording solo and at the end I just turned off the button and kept recording in a usual mode. How can I amplify the outlet sound?
The Pod Farm doesn't recognize XT Live, although the drivers are installed, why is that? And could Pod XT Live and Pod Farm be combined? I record through a real-time sequencer. And originally it's a clear signal recorded to make re-amping afterwards.
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6879 posts
  • Registered Products:6
Posted 12 December 2013 - 06:34 AM
POD Farm is not used to edit tones for the xt or X series, you would use Gearbox (or Edit)  for that.
The drop in output is likely due to different patch settings. You may need to adjust the channel volume and/or levels/gains of other effects.
If you are recording via USB, you can set the PODxt Live to send the unprocessed signal to your DAW, while monitoring the wet.
This option can be found in the Line6 Audio-MIDI Devices control panel.
Then after recording you can add the POD Farm plug-in post processing.
#3 kr0lik_roger
kr0lik_roger
  • 6 posts
Posted 14 December 2013 - 12:23 PM
I`m recording via USB. I use Gearbox. When I press the button «Record send +18», signal is not amplified.
The basic question is : How can I  amplify the signal, when I`m recording solo guitar ?
#4 kr0lik_roger
kr0lik_roger
  • 6 posts
Posted 14 December 2013 - 12:24 PM
maby tell me what settings I need to do
#5 kr0lik_roger
kr0lik_roger
  • 6 posts
Posted 16 December 2013 - 05:28 AM
up!
#6 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6879 posts
Posted 16 December 2013 - 05:41 AM
I'm not 100% sure, but I think the 18+ dB is for the Toneports and Pod Studios.
I can check the behavior on my xt tonite.
Are you recording the dry or processed signal?
#7 kr0lik_roger
kr0lik_roger
  • 6 posts
Posted 18 December 2013 - 02:16 AM
ok,check ,please.Dry signal
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 6879 posts
Posted 18 December 2013 - 07:23 AM
Definitely the dry signal is not affected by the +18dB button.
So if you are recording the dry signal and re-amping with POD Farm plug-in, there is no need for a solo boost while recording, just tweak it in the plug-in.
Also tagged with one or more of these keywords: pod
