avancinirodrigo Posted December 14, 2013 Share Posted December 14, 2013 Hi all! Is there any way to turn on an effect and turn off another at the same time? e.g. stepping on distortion enable any amp and disable any effect. Enable and disable 2 or more at the same time I know it is possible. Em pt-br caso alguém possa me ajudar? Existe algum jeito de habilitar um efeito e desligar outro ao mesmo tempo? p. ex. eu que pisar na distorção e ao mesmo tempo desligar um chorus ou algum outro efeito. Habilitar 2 ou mais efeitos ao mesmo tempo sei que é possÃvel. Thanks! Obrigado! Rodrigo Quote Link to comment Share on other sites More sharing options...
katiekerry Posted December 14, 2013 Share Posted December 14, 2013 Yes you can assign multiple Effects to a single foot switch. it explains it on page 39 in the DH500 advanced user guide V2.0... http://line6.com/support/manuals/podhd500 the link to download it is above.. Quote Link to comment Share on other sites More sharing options...
ftuller Posted December 14, 2013 Share Posted December 14, 2013 Yes, you can assign more than 1 effect to the same footswitch. If you assign 2 effects to the same footswitch and turn one effect on and the other off, then the footswitch becomes a toggle between the 2 effects. And if you want you could set it up so 2 effects turn on and a 3rd turns off at the same time, for example. Or any combination. Just assign them to the same footswitch. Quote Link to comment Share on other sites More sharing options...
AParedes Posted December 15, 2013 Share Posted December 15, 2013 This video shows how to toggle between amp/rotary cab for the solo section of a song using the HD500X edit software: http://www.youtube.com/watch?v=T1t0FYTu5RM&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
