Help, Setting The Wah To A Footswitch Instead Of Exp Switch
wah volume toe foot switch max
3 replies to this topic
#1 bullvine
bullvine
  • 1 posts
Posted 13 December 2013 - 09:01 PM
Hi all, quick question:
I'd like to be able to activate my Wah via a footswitch instead of useing the expresion pedal toe switch. I like playing live with my volume pedal around 80% it gives me some room to boost when needed and such. My problem is that in order to switch over to WAH useing the expresion pedal toe switch, I have to max out my volume pedal in order to activate it, then i'm stuck at 100% volume for my Wah when what I really want is about 80%. Is there any way around this? I've tried setting the Wah to be controlled by a footswitch but it doesn't seem to work the way that I was hopeing for.
Thanks for your time.
#2 ftuller
ftuller
  • 39 posts
  • Registered Products:1
Posted 14 December 2013 - 06:58 AM
Try freeing up the pedal for the wah by using an effect slot in your chain for a clean boost triggered by footswitch. If you need wah and boost at the same time you can assign both to the same footswitch.
The POD HD500 doesn't have a clean boost effect but there are a few ways to do it: short cable into fx loop (add fx loop to chain with +3db return for exanple), or use tube comp with 100% thresh and output to taste (+12-24), or use studio eq with flat settings and output to taste).
Here's another post on the ways to do a clean boost:
http://line6.com/sup...x/?fromsearch=1
#3 jandrio
jandrio
    Power User
  • PipPipPipPip
  • 1254 posts
  • Registered Products:5
Posted 17 December 2013 - 03:32 AM
Use the "Controller Assign screen" (see POD HD500 Advanced Guide v2.10 - English ( Rev A ), page 3-9) and  set the maximum value of  the volume pedal  to 80%,
#4 radatats
radatats
    Power User
  • PipPipPipPip
  • 2322 posts
  • LocationOrange County, NY
  • Registered Products:3
Posted 17 December 2013 - 04:02 AM
Probably easiest way is to get a second exp pedal for a dedicated wah.  I just got one from Sweetwater for $49...  Can't go wrong for that price.   :)
Also tagged with one or more of these keywords: wah, volume, toe, foot, switch, max
