M20d Does Not Find Usb Harddisk
7 replies to this topic
#1 Profett
Profett
  • 13 posts
  • Registered Products:8
Posted 14 December 2013 - 03:12 AM
I plugged into M20D a USB hard disk with external power and  stagescape does not find it .
USB stick or SD card - no problem.
Are there special harddisk that can only be used with M20D?
Profett
#2 Digital-sound
Digital-sound
    Iknowathingortwo
  • PipPip
  • 418 posts
  • Registered Products:7
Posted 14 December 2013 - 11:01 AM
I have not tried, but the manual mentions using a USB harddrive. Maybe try reformatting? Or make sure you can see it when plugged into the computer? Probably tried these things.
#3 dboomer
dboomer
    Guru
  • PipPipPipPipPip
  • 2950 posts
  • Registered Products:4
Posted 14 December 2013 - 11:14 AM
The drive must be formatted FAT32
  • 1
#4 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 582 posts
  • LocationGeorgia
  • Registered Products:11
Posted 15 December 2013 - 10:57 PM
I am in no way  affiliated with this but I use it and highly recommend it...
http://www.partition...on-manager.html
MiniTool Partition Wizard Home Edition is a free partition manager software designed by MiniTool Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista, Windows 7 and Windows 8. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions,Copying partitionsCreate partitionExtend PartitionSplit PartitionDelete partitionFormat partition,Convert partitionExplore partitionHide partitionChange drive letterSet active partitionPartition Recovery.
and a + 1 on DB's post
May you be blessed and our Lord Jesus keep you!!!
#5 kangrga
kangrga
  • 2 posts
Posted 07 January 2014 - 05:38 PM
I tried to use a USB 3.0 HD that I bought at Cosco.  The light came on the HD but it wouldn't work.  I read this post and learned that the HD was in NTFS format.  I followed the above post and was able to reformat the HD to FAT32.  My one question is does the HD need to have external power or will it work off of the MD20?
Thank you,
Kangrga
#6 JeffersteinVS
JeffersteinVS
    Iknowathingortwo
  • PipPip
  • 161 posts
  • LocationBoston
Posted 07 January 2014 - 07:45 PM
not a fix to your issue but more of a recommendation..regardless of the size of the drive you are limited to a max recording time of i believe 3.5- 4 hours so there is no point of getting a large storage external.  you can get a 32 gig sd card for 17$ on amazon. i would just buy multiple SD cards before I use a mechanical external hard drive imho. SD is smaller and not susceptible to shock damage etc.
Complete Dream Stage./JTV-59k/HD500X/RELAY G30  Guitar Player for VelvetSkies. 90's to Modern Party Rock Boston Ma. VelvetSkiesBand.com
#7 jeanpicasso
jeanpicasso
  • 60 posts
Posted 08 January 2014 - 12:21 AM
Thank you,
Kangrga
I believe that the HDD needs external power supply to work with M20D.
I have tried with 3 different USB powered HDD, with no luck. my old usb 2.0 HDD with power supply works like a charm. :)
#8 jaminjimlp
jaminjimlp
    Gear Head
  • PipPipPip
  • 582 posts
  • LocationGeorgia
Posted 11 January 2014 - 11:23 AM
if there is no way to power it besides the usb connector you can get a powered usb [2.0 or higher if available] hub so that u can use the HD you have invested in.
