Pod Hd500 Help
distorting clipping volume
11 replies to this topic
#1 jamminforever
jamminforever
  • 50 posts
  • Registered Products:5
Posted 14 May 2013 - 09:16 AM
Hello all, been having some frustrating issues with my POD 500. First off, my setup.
Mesa Boogie Mark V head
Mesa Boogie Recto 2x12 horiz cab
pod hd 500
RUNNING IN 4 cable method.
It seems as if sometimes, everything sounds great, and I'll have a great show or practice. There are a few other times when I'll get volume drops when engaging the effects loop of my amp, and or my cleans coming out of my amp are really distorted. This issue happens with NO change to the amp or the POD 500. Does this sound like a defect issue with the pod 500? I mean, one gig, everything will sound great, no problems, and another gig I'll get volume drops, and horrible distortion on my Mark V cleans, which BTW, are some of the best I've heard! I haven't made any changes to my setup.
#2 hurghanico
hurghanico
    Guru
  • PipPipPipPipPip
  • 3764 posts
  • LocationBologna, Italy
  • Registered Products:4
Posted 14 May 2013 - 09:47 AM
save your patches and
try a global settings reset
intructions here: http://line6.com/support/docs/DOC-2222
probably it will cure the problem
#3 jamminforever
jamminforever
  • 50 posts
Posted 14 May 2013 - 11:55 AM
Thanks! I will give it a shot soon, hope that clears things up. BTW, for anyone else that reads this, has anyone had any issues, like I described in my post at the beginning of the thread?
#4 jamminforever
jamminforever
  • 50 posts
Posted 14 May 2013 - 12:37 PM
Forgot to mention that I'm using the 500 for effects ONLY. No amp sims or speaker sims.
#5 moondancer
moondancer
  • 99 posts
  • LocationGermany
  • Registered Products:2
Posted 15 May 2013 - 03:02 AM
Have you once plugged in a headphone, when the problems appears, just to verify that the problems comes from the HD 500?
Stay tuned brothers
Regards Edgar
#6 bjnette
bjnette
    Power User
  • PipPipPipPip
  • 1003 posts
Posted 15 May 2013 - 04:37 AM
I'd really check your cabling first. Followed by jacks in the Amp and HD.
But, I have noticed patch differences with different guitars as some output differently to others.
You are on the right track if the above checks out with looking for what changed. Because if it happens only now and then, then there is a change causing it.
Subjectively in bed before you go to sleep, really take a look at it. Scan the last few gigs.
You'll find the change.
#7 jamminforever
jamminforever
  • 50 posts
Posted 15 May 2013 - 10:26 AM
Would the quantity and quality of the electricity supply cause this?
  • 1
#8 moondancer
moondancer
  • 99 posts
  • LocationGermany
Posted 16 May 2013 - 02:55 AM
Don't you use the original power supply? I found out that the hd 500 need a strong ps. I tried some supplies other than the line6 and the hd 500 doesn't work with them. The 500 starts and restarts frequently.
Even sometimes - using the original ps - it restarts once when connected to the power supply.
The power supply could be a reason for your problems, but IMHO I don't think so.
Stay tuned brothers
Regards Edgar
#9 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
  • Registered Products:1
Posted 16 May 2013 - 05:35 AM
just for reference the power supply output is 9vdc@3amps
I'M SO HAPPY!
#10 jamminforever
jamminforever
  • 50 posts
Posted 16 June 2013 - 01:38 PM
Sorry guys for not responding in a timely fashion. What I meant by power supply was not the power adapter, but rather the quality of the the electricity coming from the source. aka... wall outlet...
Also, I think it also may be as to what gets plugged in where. I run a rather complicated setup that i would like to get away from. I have a Mesa Boogie Mark V head, with a Mesa Boogie 2x12 dual rec cabinet. I use the pod hd500 in a 4cm method strictly for effects only. No amp and cab effects. I also use g50 relay wireless systems for 3 guitars, with one base receiver and 3 transmitters, each on their own frequency. I've been paying attention to what gets plugged in where... I try to plug my amp into a different outlet than the pod hd. So far when I do this, I find that I do not get any issues.
#11 VinayPrasad
VinayPrasad
  • 7 posts
Posted 29 July 2013 - 10:19 AM
Hey! Iwanted to know if i could use this adapter for my hd500 since i'm in India and i cannot afford to order all the way from the US. Turning out too expensive.
http://www.ebay.in/i...=item3cd4011d4e
Thanks!
#12 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17700 posts
  • LocationClemmons, NC USA
  • Registered Products:16
Posted 29 July 2013 - 10:56 AM
the output should be acceptable, just make sure the polarity is correct on the tip... i didnt see any info on that/
