diegoboccardi Posted December 15, 2013 Share Posted December 15, 2013 Hello, i've a problem in launching reason 7.01 Everything worked perfectly until i installed line 6 pod farm 2.5 Now when i try to launch reason i've this message "Failed to load Line 6 support files. Your installation is damaged. Please reinstall Reason" I removed everything about Line 6 products (drivers etc.) and tried to reinstall Reason but when it starts i've always that message….i tried to remove Reason too but noting…when i reinstall i have that message. Please help me. Thnks Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted December 16, 2013 Share Posted December 16, 2013 you probably just needed to run the license manager for pod farm 2, probably a little late for that now. Quote Link to comment Share on other sites More sharing options...
Triryche Posted December 17, 2013 Share Posted December 17, 2013 Just ran across this. Maybe the "Uninstaller Pro" mentioned here might help. http://line6.com/support/topic/4468-found-a-solution-for-failed-device-detection-or-no-authorized-device-issue-on-the-pc-finally/ (I have no experience with this utility) Quote Link to comment Share on other sites More sharing options...
angelcarrera Posted August 3, 2015 Share Posted August 3, 2015 So how did this get solved? I have the same exact issue. 1 Quote Link to comment Share on other sites More sharing options...
Migs72 Posted October 26, 2019 Share Posted October 26, 2019 I found a solution for this issue, is anyone still interested? Quote Link to comment Share on other sites More sharing options...
Gaz_Ham Posted October 27, 2019 Share Posted October 27, 2019 Post the soloution you found. Any searching users will be grateful 1 Quote Link to comment Share on other sites More sharing options...
Migs72 Posted October 31, 2019 Share Posted October 31, 2019 The solution I found is for Mac, the OS I still use is El Capitan installing Reason 6.5, also tried it in Mavericks. 1) Go to applications and in the reason folder to the reason app icon, right click on it and press show package contents. 2) Go into the folder “Contents” and then “Resources” and then into the folder “Installation”. 3) inside that folder you will find a package named “Line 6 TWXT Framework” run the package and restart the computer. Now reason should be able to load. If that doesn’t work you might need to run the “Authorizer.pkg” ”CmDriver.pkg” and ”CmKext.pkg” inside “Resources” too. Hope it helps someone, but try it at your own risk. 1 Quote Link to comment Share on other sites More sharing options...
Migs72 Posted October 31, 2019 Share Posted October 31, 2019 On 10/27/2019 at 4:01 PM, Gaz_Ham said: Post the soloution you found. Any searching users will be grateful There it is, hope it helps. If I get my hands on a Windows PC I’ll post the solution for Windows. So far I only have a Mac. Quote Link to comment Share on other sites More sharing options...
Migs72 Posted November 1, 2019 Share Posted November 1, 2019 On 8/3/2015 at 5:43 PM, angelcarrera said: So how did this get solved? I have the same exact issue. I have a solution for Mac in the comment below, hope it solves your problem too. Quote Link to comment Share on other sites More sharing options...
