arislaf Posted December 15, 2013 Share Posted December 15, 2013 Which one to buy? Which is appropriate? Please help. Quote Link to comment Share on other sites More sharing options...
eenymason Posted December 16, 2013 Share Posted December 16, 2013 measure the nut on your 700 - and here is the info on graphtech sizes: http://www.graphtech.com/products/brands/black-tusq-xl/black-tusq-xl-guitar-nuts to fit, take out your 700 nut, and place the tusq next to it to work out how much to sand down. place sandpaper on a flat surface and VERY carefully keeping it square, sand down to same height. Edit: measure your string gaps - this is more important than total nut width - I sanded down the ends of the nut also, taking off maybe 5-6mm off the total width (2-3mm each side) My graphtech nuts are barely slotted - ie the strings sit "high in the saddle", so you need to take this into consideration working out the finished height of the nut. You could order 2 nuts just in case you take it too far, but I just kept trying it out to check for height, and then sanded a little bit more, etc At least this is what I did for my 600, and I guess translates to the 700 also, as long as the nut has a flat bottom - good luck. I did this actually for my 600, and then for two strat clones which received the guts of the 600 and a 300 respectively - see link: http://line6.com/support/topic/4383-best-graphtech-nut-for-my-600/ 1 Quote Link to comment Share on other sites More sharing options...
arislaf Posted December 17, 2013 Author Share Posted December 17, 2013 Thanks man! Quote Link to comment Share on other sites More sharing options...
